no low pressure oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-11-2010, 03:09 AM Thread Starter
SLOW STROKIN's Avatar
Send a message via AIM to SLOW STROKIN
no low pressure oil
yes if I let me truck sit over night it will loose lpo looking for any ideas thinking bad oring on pickup
95 CC PSD DRW 4:11 4x4 3" dp 4" exhaust 238's 100% over IDM mod FASS fuel pump 17* hpop 38R turbo SD ic 3" intake manifolds and spider with a custom fuel system BTS converter suncoast overhaul kit [email protected]
SLOW STROKIN is offline
post #2 of 8 (permalink) Old 04-11-2010, 03:30 AM
Demon Dually
speeddemon31176's Avatar
Re: no low pressure oil
The low pressure oil pump doesn't hold pressure once the engine is shut off. If should build pressure within seconds of turning the engine over however. If it isn't building pressure when cranking then yes either the pickup is leaking back to the pan or more likely your LPOP is gone south.
speeddemon31176 is offline
post #3 of 8 (permalink) Old 04-11-2010, 08:01 PM
oil burner
tughill283's Avatar
do you have a stock guage? my stocker doesnt move till the truck idles for a good 2-3 seconds.
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #4 of 8 (permalink) Old 04-11-2010, 08:08 PM
Don't EFN worry about it
Aljay's Avatar
Mine gets pressure while cranking. I don't really trust the stock gauges and when things get better $$$ wise I will get an auto meter trio so I know whats up.
Tuned by T Wildman
Aljay is offline
post #5 of 8 (permalink) Old 04-11-2010, 08:13 PM Thread Starter
I know the truck is loosing lpo because it will start untill it runs out of hpo I can pull the lpo sender out and no oil while cranking
post #6 of 8 (permalink) Old 04-11-2010, 08:19 PM
Demon Dually
Then you answered your own question. The LPOP is shot. Replace it and move on.
post #7 of 8 (permalink) Old 04-12-2010, 12:25 AM
OEM Moderator
Tom S's Avatar
When you dig into that make sure the front cover is not scored. I have a early one I plan on putting up for sale soon if you need one.
Tom S is offline
post #8 of 8 (permalink) Old 04-12-2010, 01:57 PM Thread Starter
thanks for the info thats what I was thinking I have the cab off now about to tair into it I am also going to mod my fuel system and install a sd turbo and intercooler while I have it apart
