I found a parts truck is it worth it? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-11-2010, 02:44 AM Thread Starter
I found a 97 f-250 4x4 5 speed for $2000 dollars. Needs motor and turbo. It has a brand new set of BF Goodrich mud terrains, 305/70/R16, New auto locking hubs, standard transmission with New clutch, New pressure plate, New throw out bearing, New clutch master cylinder assembly, whole clutch system has been replaced, New U-joints, New batteries still under warranty, New lift pump, New high pressure oil pump.
I have a 96 that will need a new clutch soon and third gear grinds pretty band and sometimes fourth will also. I talked to the guy and he said the trans is tight. The truck was dusted out and has no compression but is in the truck.. It has 320,000 miles on the truck. Is it worth $2000?
96 f-250 5 speed, 4x4, 6637 intake, 3" down pipe to straight pipe, swamps tunes, Rosewood stage 1`s
village idiot is offline
post #2 of 12 (permalink) Old 04-11-2010, 08:23 AM
What else?
smokyred's Avatar
Re: I found a parts truck is it worth it?
Sounds like it to me, are you going to part it? I could use some Mud Terrains.
Dave
smokyred is offline
post #3 of 12 (permalink) Old 04-11-2010, 02:54 PM
Don't EFN worry about it
Aljay's Avatar
If you need all you say you do I'd be all over that deal like a drunk on a hooker on a friday night after payday. Better hop on that one just the new parts alone is worth it.
Tuned by T Wildman
Aljay is offline
post #4 of 12 (permalink) Old 04-11-2010, 03:56 PM Thread Starter
Lol like a drunk on a hooker huh!!! I`ll have to remember that one. I think i`m going to get it. Hes sending me pics of it, i can`t see it in person.
post #5 of 12 (permalink) Old 04-11-2010, 04:00 PM Thread Starter
This may be a dumb Question but with the motor getting dusted out shouldn`t have hurt the oiling system or the injectors should it?
post #6 of 12 (permalink) Old 04-11-2010, 06:28 PM
Demon Dually
speeddemon31176's Avatar
No the oil system and injectors should be fine but it probably wiped out the turbo and the cylinder walls and rings are probably in need of repair. What are your plans for the dusted engine if you get the truck...hint hint?
speeddemon31176 is offline
post #7 of 12 (permalink) Old 04-11-2010, 06:31 PM
does it have the stock aluminum wheels if so how much for em?
Burning DIESEL.....Burning DINOSAUR Bones- J.R. Cash
96' Powerstroke CC Bone stock..... DIY intake, exhaust, and PHP 6 pos. soon. Hopefully
Jprejean is offline
post #8 of 12 (permalink) Old 04-11-2010, 06:54 PM Thread Starter
Yeah the trubo is gone and he said it has no compression. I don`t plan on keeping the engine. If i buy it i will be selling the stock aluminum rims. My plans for it would be to keep the hpop, the injectors (maybe) the idm, the tires, and the ecm, and whatever little odds and end i may need. But basically i will sell everything else or just sell the truck rolling along with the dusted motor. I doesn`t look i`ll have a hard time selling things does is lol.
post #9 of 12 (permalink) Old 04-11-2010, 07:04 PM
Demon Dually
I would actually be interested in the engine for a rebuild so keep me in mind. I would come and pick it up too. Road trip away from the wifey.
post #10 of 12 (permalink) Old 04-11-2010, 07:10 PM Thread Starter
you would come all the way to texas to pick the motor up?? wow is she that bad lol.
