who can measure a water pump for me? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-08-2010, 10:56 PM Thread Starter
hit n miss
Peroni's Avatar
Question who can measure a water pump for me?
Anyone have an early 94-95 water pump laying around that could take a quick measurement? I need the dimension from top of the outlet housing to top of the thermostat bypass sealing surface. This needs to be an accurate measurement, either with a depth mic or dial caliper with a proper depth attachment.
97 Green F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, electric fuel, CCV mod, 6.0 fan, tru-cool 4739, Swamps 175/30% injectors, stage I Stealth pump, LASB turbo, Spearco 6.0 cac, live tuned 442hp/860tq.
Peroni is offline
post #2 of 11 (permalink) Old 04-08-2010, 10:59 PM
gnxtc2's Avatar
Re: who can measure a water pump for me?
Does it have to be a 94-95 pump? I have one for a '97 lying on my bench.
What are your plans?
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #3 of 11 (permalink) Old 04-09-2010, 12:14 AM
14psd's Avatar
same pump should work....what ^ he said what is your plans?
Todd
__________________________________________________ _________________________________
'95 F-350 daully, Super Cab, 230K+ miles, 2 wd, automatic, Bean's stage 1, shimmed fpr, 3" down pipe, superchip, gauges boost, EGTs, trans, and volts, missing Kitty & muffler, Homemade tymar set-up, HPX mod, CCV mod, and air bags in the rear
14psd is offline
post #4 of 11 (permalink) Old 04-09-2010, 01:06 AM Thread Starter
hit n miss
Peroni's Avatar
This is just for personal amusement at the moment. Pump in my pic is an iron body from IH and measures 1.455. I want to know what the early 94-95 pump measures. Billy since you already have a 97 pump on the bench could you measure that for me? Save me taking mine apart this weekend. I'm curious as to if it is the same as the IH pump or not.
Peroni is offline
post #5 of 11 (permalink) Old 04-09-2010, 03:34 AM
Patrick Feeley's Avatar
The early pumps used the short thermostat while the later ones used the long thermostat (that's why you can easily get a 203F thermostat for the early trucks, but you have to get the Dieselsite 203F thermostat for the later trucks). Cheers!
Patrick Feeley is offline
post #6 of 11 (permalink) Old 04-09-2010, 03:49 AM
What else?
smokyred's Avatar
Patrick is right, the early pumps are not the same as the later pumps.
Dave
smokyred is offline
post #7 of 11 (permalink) Old 04-09-2010, 08:01 AM
Shortbus driver
u2slow's Avatar
The IH pump uses the 94-95 style short thermostat. Stant makes a 205* stat. I did the conversion a couple years ago.
'93 F250 2wd, 7.3IDI/5spd/4.10
'89-93 Dodge CTD jalopies
u2slow is offline
post #8 of 11 (permalink) Old 04-09-2010, 06:30 PM
ohh bee ess
202wagon's Avatar
^^^correcto! '97 uses the the longer t-stat (195* ?). Napa also has the 205* shortie early 'stat (probably made by Stant).
1997 F-250HD XLT ECLB 4WD, built E4OD, 4.10 LS, baby Swamp's, MPRP 4" turbo back w/ 3" dp, S&B intake, Edge Evo (for now...yes I know), 167k
*SOLD*1997 F-250HD XLT ECLB, 4WD, BTS E4OD, 3.55, MBRP 4" turbo back w/ 3" dp, S&B intake, 6 position chip w/ BTS tunes, Auto Meter pre-turbo py
Leaving a carbon footprint as big as Sasquatch !
202wagon is offline
post #9 of 11 (permalink) Old 04-09-2010, 06:56 PM
oil burner
tughill283's Avatar
yup,my 96 measures 2.42
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #10 of 11 (permalink) Old 04-09-2010, 09:22 PM
gnxtc2's Avatar
Roughly 2.345" But it's all together different.
Billy T.
[email protected]
Other vehicles
gnxtc2 is offline
