Strange Fuel Leak from front tank? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-08-2010, 08:13 PM Thread Starter
TNScrambler's Avatar
Send a message via AIM to TNScrambler
I have a buddy with a '94 F350 crew cab dually powerstroke 5 speed, he filled up his rear tank and put another $10 or so into the front tank and parked it on a hill infront of his house. After a day or so he noticed a decent sized fuel leak under his truck. I crawled up under the truck and can see that the frame is wet just behind (to the rear) of the filler neck. I used a flashlight and a mirror to see as much as I could on top of the tank, the sending unit looks dirty but dry, the top side of the filler neck connection and clamp look dirty and dry but the bottom of the clamp (towards the frame) appeared cleaned off as though maybe it was washed with fuel. None of the lines or anything obvious was wet as far as I could find.
Any common issues or problems before we drop the tank?
Thanks,
Justin
2000 Excursion Limited 7.3 Auto 3.73s on 285s adj. Rancho Shocks (with dual front) tripple guages and a diablo chip
TNScrambler is offline
post #2 of 3 (permalink) Old 04-08-2010, 11:02 PM
gnxtc2's Avatar
Re: Strange Fuel Leak from front tank?
If I stuff either tank while it's cool out then it's hot outside the next day, the tank will leak from the rollover valve grommet. As the ambient temp increases, the diesel fuel expands thus creating a leak.
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #3 of 3 (permalink) Old 04-09-2010, 03:36 AM Thread Starter
Billy T.
[email protected]
That could be a possibility, he says he just put $10 in front tank, but maybe he got that backwards and filled the front tank and put 10 in the rear. It also did get really warm last week when he says it happened.
Maybe this will be it.
