Ok im blind - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 04-07-2010, 08:30 PM Thread Starter
Zrock's Avatar
Ok im blind
I was looking for the electrical connector for the Exast backpresure Valve.. I cannot find it anyware. I can see the controll rod that goes inbehind the pedistal but thats it?
Were is it? I thought it was front and to the right
http://i300.photobucket.com/albums/n...P4070001-1.jpg
Zrock is offline
post #2 of 13 (permalink) Old 04-07-2010, 09:14 PM
Re: Ok im blind
In your second picture there is a "stud" in the middle. It should be just in front of that look down there.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
BlindViper is offline
post #3 of 13 (permalink) Old 04-07-2010, 10:42 PM
<---Best intake plenums
powertrip's Avatar
Re: Ok im blind
in your third pic you see that little wrapped white wiring? Follow it and theres your plugin.
RDRCM #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke
powertrip is offline
post #4 of 13 (permalink) Old 04-08-2010, 12:27 AM Thread Starter
Zrock's Avatar
Re: Ok im blind
Looked everyware in the front of the pedistal nothing their even stood on my head trying to find it...
Zrock is offline
post #5 of 13 (permalink) Old 04-08-2010, 12:28 AM Thread Starter
Zrock's Avatar
Re: Ok im blind
That wire goes to teh back side of the valve cover in the second pic is showing were it goes into the valve cover at.
Zrock is offline
post #6 of 13 (permalink) Old 04-08-2010, 01:07 AM
Harl
Harl's Avatar
Send a message via AIM to Harl
Re: Ok im blind
No bud. Thats your fuel line your seeing.. Follow the wire towards the front of the turbo. Its monted on the side of it.
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
post #7 of 13 (permalink) Old 04-08-2010, 01:19 AM Thread Starter
Zrock's Avatar
Re: Ok im blind
Dohh i must have gotten my fingers crossed when i was folowing it towards the firewall and crossed over to the fuel line. Going towards the front of the truck it seems to go under the fuel filter and has a connector just inbehind the hose connection that you can't see. From all teh pic's i was able to dig up it looks like the connector was fairly easy to see but i can see it no ware... guess ill charge up the trouble light and go look again... Anyone have a really good pic?
Zrock is offline
post #8 of 13 (permalink) Old 04-08-2010, 02:42 AM
Harl
Harl's Avatar
Re: Ok im blind
Looking at the truck the plug is on the right side of turbo towards the bottom.. Ill try and find you a pic.
Cody,17
Harl is offline
post #9 of 13 (permalink) Old 04-08-2010, 02:47 AM
Harl
Harl's Avatar
Re: Ok im blind
Ohh my mistake. I see what you mean now Its not where its actualy suposed to be.. Well you could cut one of the wires and put it on a switch so u can use it when u want it and shut it off when u dont want it.
Cody,17
Harl is offline
post #10 of 13 (permalink) Old 04-08-2010, 03:33 PM Thread Starter
Zrock's Avatar
Re: Ok im blind
ya thats what i was thinking of doing. Putting a switch under the hood for winter use... So is that the right wire i found? Like i said all teh pic's i have seen their is no pigtail on the EBV and i still havent beeen able to find the other end of this wire
Zrock is offline
