Changed feed pump now it wont run!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-23-2008, 02:44 AM Thread Starter
Speedy
Speedy's Avatar
Send a message via AIM to Speedy
I changed my feed pump and resealed the fuel bowl with a seal kit cause i had a leak. got everything back together and truck ran noraml i let it run for couple mins and shut it off to check for leaks. restarted it and it idled for couple mins and begun to idel rough then it died. Now it wont restart and I belive I have one of my batteries going bad. So with battery chargers on it all it does is crank and smoke . I can't get it to take off. I figure its full of air so how do i get it bled out.
1996 F250 Powerstroke 4x4.
3inch down pipe to 4inch exhaust 6inch tip, homemade air intake WIX 6637 filter element, gauges, TS 6-position,XM Radio, 2 inch level kit, Eagle Alloy 186 seires wrapped in 305-70-16 Firestone Destinations MT and more to come.
Speedy is offline
post #2 of 6 (permalink) Old 01-23-2008, 02:49 AM
OEM Moderator
Tom S's Avatar
Re: Changed feed pump now it wont run!!
The air should bleed out on its own as the system is a flow through the head design. If the batteries are low the truck may not start. I would let the batteries fully charge as step one.
Tom
Tom S is offline
post #3 of 6 (permalink) Old 01-23-2008, 03:01 AM
Don't EFN worry about it
Aljay's Avatar
What Tom said, Need to have a good charge on them batts. Engine will have to spin at least 750 rpms to start and run.
Tuned by T Wildman
Aljay is offline
post #4 of 6 (permalink) Old 01-23-2008, 03:38 PM Thread Starter
Speedy
Speedy's Avatar
Well I let it charge overnight. Tried to start this morning its just not cranking fast enough. The batts are junk so I gonna go get a new set after college today.
Speedy is offline
post #5 of 6 (permalink) Old 01-24-2008, 03:23 AM
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
Its proably from your K&N filter allowing to much dirt into your engine and it fragged everything so you have no compression. But serioulsy, might want to check about getting a different air filter. Also welcome to PSN!!
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #6 of 6 (permalink) Old 01-24-2008, 01:00 PM Thread Starter
Speedy
Speedy's Avatar
I got it to run finally. New batts and bled the air out of the rail ( two plugs one on each head you back out couple turns 1/4in. pipe plug.
Speedy is offline
