water pump gasket? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 04-06-2010, 12:39 AM Thread Starter
washingtoncoastie's Avatar
water pump gasket?
Ok, noticed a puddle under my truck today. Thought it was another fuel leak since I just got done fixing one. But it is coolant, I think coming from the water pump gasket on the front of the engine. How hard is it to replace this myself? It looks like I might have to remove a lot of stuff to get access at it. Any help would be awsome.
washingtoncoastie is offline
post #2 of 17 (permalink) Old 04-06-2010, 01:29 AM
What else?
smokyred's Avatar
Re: water pump gasket?
I would recheck the area carefully, it may be leaking from the pump weep hole. The pump uses an o-ring to seal to the engine and very rarely leaks there.
To get the pump off you need to remove the fan and shroud first, so you'll need a large fan wrench to get the nut broke loose, 2 7/8" IIRC.
After that you'll need to drain the coolant and pull the upper and lower hoses off, along with the heater hose. Then you'll just have the wire for the water temp sender and the bolts that hold the pump on.
Dave
smokyred is offline
post #3 of 17 (permalink) Old 04-06-2010, 03:30 AM Thread Starter
Where should I be looking for the weep hole? I didn't get a look at it too well cause I was actually in the process of selling my mercedes diesel. Still learning the powerstroke...
post #4 of 17 (permalink) Old 04-06-2010, 03:33 AM Thread Starter
Oh, by the way it is a pretty steady drip comming from where ever it is at. But stops after a few minutes after it is turned off.
post #5 of 17 (permalink) Old 04-06-2010, 03:44 AM
I like turtles
NE-STROKE's Avatar
drip hole should be on top of pump housing right behind where you undo the 4 bolts.
08 duramax ccsb efi live, air dog 2, isspros, 5 inch exhaust and some other cool things. 2001 duramax 2wd (Project truck)
Once had a signature that had some bad ass stuff on it. Now its back to crap.
NE-STROKE is offline
post #6 of 17 (permalink) Old 04-06-2010, 03:47 AM
gnxtc2's Avatar
Billy T.
[email protected]
'97 Black F250HD SC 3.55s, Punisher trans, PI Converter, Dana 60 RSK w/ V & C SD springs,
PIS 175/80s, HB Jr, Comp910s, Smith Bros PRs, ARPs, Fluidampr, IC, E-Fuel, CJC Traction blocks, HFHV IDM, T4/BASB, 262K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
-1993 Geo Prizm (beater)
-2016 F350 DRW Utlimate
gnxtc2 is offline
post #7 of 17 (permalink) Old 04-06-2010, 03:53 AM
I like turtles
NE-STROKE's Avatar
he beat me. on my spare motor its on the bottum. On the one in my truck its on the top.
post #8 of 17 (permalink) Old 04-06-2010, 04:42 AM
Terminator Nation
If you don't save all of the coolant, you will also need 4 gallons of Fleetrite coolant or Ford equivalent for 7.3 PSD diesels, not the regular auto antifreeze. Also Ford additive FW-16 or DCA-4, 4 pints. You have a 32 quart coolant system.
old man dave is offline
post #9 of 17 (permalink) Old 04-06-2010, 05:15 AM Thread Starter
And where could I pick up those additives? Any place other than ford?
post #10 of 17 (permalink) Old 04-06-2010, 05:17 AM
I like turtles
NE-STROKE's Avatar
http://www.cumminsfiltration.com/pdf...es/LT15070.pdf
Prestone :: Products : PrestoneHeavy Duty Antifreeze/Coolant
Fleet Charge Antifreeze
__________________
