Help! Bad oil leak? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-05-2010, 07:52 AM Thread Starter
Help! Bad oil leak?
Ok, so today i finished up my injector install. Then i cranked the truck, drove around for about 50 miles, got back to the shop, parked on a small incline at the door to the shop, after pulling in and walking back to the door i noticed a bunch of oil spots all over the ground. i had checked the oil level before leaving, it was about midway between add and full, when i checked after returning, i didn't really wait for the oil to settle and it read right at the add mark. then i topped it off to full and headed out, stopped again after about 15 miles, looked under the truck, dripping a little, but nothing ridiculous, checked the oil level, it was about 3/4 between add and full, so i contined my drive for another 35-40 miles, pulled up on a pretty steep hill, looked under the truck, lots of oil dripping down, pulled into a parkin spot, let the oil settle for about 20 minutes, checked it and it was at the add line and huge oil spots under the truck. looking under the truck, both sides of the engine are nice and wet, all the way back to the back of the transmission oil is dripping down. my original thought was that maybe oil i had purged from the cylinders after installing the injectors had set in the valley and was dripping down the back. there is a good deal of wetness under the turbo and i thought maybe the oil left in the cylinders while purging came through the exhaust and dumped out the waste gate (dunno if that's possible). looked all around the valve covers and don't see any wetness. while looking at the oil pan, it looks like some oil is coming out of the dipstick grommet, maybe i dislodged something when working around the dipstick while doing the valve covers? also, no HPOP codes in the computer. Need some help fast. Thanks a lot, sorry for the long post
-John-
1996 F-250 Ext Cab Long Bed 4x4 w/ a few mods
jmsmith76 is offline
post #2 of 10 (permalink) Old 04-05-2010, 03:36 PM
Cratos's Avatar
Re: Help! Bad oil leak?
Wash down the valley with water and simple green, dry it off and start looking at idle. If it’s at the dipstick it has to be pushed in the fitting on the pan there is an o-ring you may have dislodged. Or it could be the turbo o-rings if you had it off.
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #3 of 10 (permalink) Old 04-05-2010, 04:01 PM Thread Starter
didn't have the turbo off, i'll clean up the engine this afternoon and check it out
-John-
post #4 of 10 (permalink) Old 04-05-2010, 06:12 PM Thread Starter
here's a picture. looks to be coming out of the dipstick fitting, but still some coming from the top, and it's getting back onto the transmission... here's a picture...
-John-
post #5 of 10 (permalink) Old 04-05-2010, 07:12 PM Thread Starter
took it to see a fella i know and he looked at it for about 2 minutes and said it's the turbo pedestal. anybody know how hard it is to change?
-John-
post #6 of 10 (permalink) Old 04-05-2010, 07:14 PM Thread Starter
also, can i just replace the o-rings or do i have to replace the whole pedestal?
-John-
post #7 of 10 (permalink) Old 04-05-2010, 10:35 PM
Demon Dually
speeddemon31176's Avatar
You can replace just the o-rings.
speeddemon31176 is offline
post #8 of 10 (permalink) Old 04-05-2010, 11:09 PM Thread Starter
alright good deal. should i go ahead and delete the EBPV?
-John-
post #9 of 10 (permalink) Old 04-05-2010, 11:12 PM
yes got and delete the ebpv.
also if it were me and I had the funds I would upgrade the turbo since your gonna be pulling the whole thing out of there.
02 f250
countryboyrob is offline
post #10 of 10 (permalink) Old 04-05-2010, 11:34 PM Thread Starter
definitely don't have the cash for that right now since i just upgraded the injectors. lol
-John-
