oil leaking out of top of dipstick tube - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 04-05-2010, 05:19 AM Thread Starter
look what i can do
1badpsd's Avatar
what would cause this and what do i need to do to fix it? i smell oil in the cab all the time now and it was leaking very badly till about two weeks ago and i got it to stop but i changed my oil friday and now its leaking again. thanks for any help
1badpsd is offline
post #2 of 13 (permalink) Old 04-05-2010, 05:26 AM
Re: oil leaking out of top of dipstick tube
Sounds like you've got a lot of crankcase pressure for it to be coming out of the dipstick tube. Check your ccv and make sure its not clogged or something
ericrider07 is offline
post #3 of 13 (permalink) Old 04-05-2010, 05:29 AM Thread Starter
look what i can do
1badpsd's Avatar
okay ill check it tommorow i have it run into the exhaust but ive been wondering if the hose is stopped up
1badpsd is offline
post #4 of 13 (permalink) Old 04-05-2010, 05:36 AM
Waljon's Avatar
How do you have it in the exhaust?
96 F250 ext cab 6637 3"down pipe 4" straight pipe ebpv delete ccv mod firestone air rite suspention
Waljon is offline
post #5 of 13 (permalink) Old 04-05-2010, 05:46 AM
If thats the case theres your problem.
post #6 of 13 (permalink) Old 04-05-2010, 06:05 AM Thread Starter
look what i can do
1badpsd's Avatar
i ran hose from my ccv to the back of the cab and got a short piece of pipe and welded into the exhaust pretty easy really
1badpsd is offline
post #7 of 13 (permalink) Old 04-05-2010, 12:49 PM
Waljon's Avatar
If you didn,t angle the pipe just right in the exhaust I would say that is your problem seen it happen now several times the angle has to be just right for it to work that is how I have mine too I welded my ccv in where the cat would have been and put it on a 45* angle with an 45* angle cut on the end of the pipe that was welded into the exhaust .
Waljon is offline
post #8 of 13 (permalink) Old 04-05-2010, 12:55 PM
7.3 Enthusiast
91turbogsx's Avatar
I agree. You need the exhaust to "pull" the vapors out not push them back in. So where it joins the exhaust is and at what angle, very important.
'02 F-350 4x4 Black RC/LB
4" Lift with 35's. OUO Traction Blocks
20x10 Fuel Throttle's
Lots of deleted parts...
Custom fuel system w/ Strictly Diesel RR
Dieselsite Adrenaline HPOP
DI Up-Pipes
DP-Tuned
and more...
91turbogsx is offline
post #9 of 13 (permalink) Old 04-05-2010, 04:12 PM
OEM Moderator
Tom S's Avatar
You are not the first one to have bad luck with the exhaust trick.
Tom S is offline
post #10 of 13 (permalink) Old 04-05-2010, 05:03 PM Thread Starter
look what i can do
1badpsd's Avatar
well i ran it in at an angle so it would pull the vapors.i did it several months ago and havent had and issues till about a month ago then it started leaking from the top of the tube but i guess ill take the hose lose and clean it out
1badpsd is offline
