Cutting off - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 04-05-2010, 01:50 AM Thread Starter
Cutting off
Well i have done tore this truck apart and still cant figure it out,maybe someone can tell me somethn to check that i have missed. It will crank and run fine then it may run sluggesh or if u try to get in the throttle it will just bog but if u back off and ease into the throttle it will go pretty good,but then a minute later it will run fine.But this is where it gets good,it will start to jump and buck and everything else and just cut off,and u may crank on it for an hour or a minute and it will crank back up and u may drive a mile or a hundred miles and do it again. done changed CPS 3 times,no good,checked for codes and dont have any,changed fuel filter no good,put another computer in it and didn help,i put a guage on it to watch the fuel pressure and just sitting in the yard and when it starts runnig bad and cuts off the fuel pressure is still up. I am just absolutely lost is there somethn somewhere im missing? This is an OBS 350 to.
fastmust88 is offline
post #2 of 29 (permalink) Old 04-05-2010, 03:22 AM
Inmate #1
RubberDuck's Avatar
Re: Cutting off
Fuel bowl heater? Valvecover harness pins? FPR screen clean?
RubberDuck
1995 F350 4x4 CC Dually-Rockee
1995 F350 4x4 Reg Cab Dually-3.0 Puller-Bobbie's Kitchen Pass
RubberDuck is offline
post #3 of 29 (permalink) Old 04-05-2010, 04:01 AM Thread Starter
Re: Cutting off
Ive checked the screen. dont no about the valve cover pins or the heater. How could the heater be a problem?
post #4 of 29 (permalink) Old 04-05-2010, 04:18 AM
Inmate #1
RubberDuck's Avatar
Re: Cutting off
If that heater puck in the fuel bowl is shorting to the side of the bowl, it will shut the truck off like you turned the key off.
RubberDuck
post #5 of 29 (permalink) Old 04-05-2010, 04:31 AM Thread Starter
Re: Cutting off
Ill have to check that,not even sure if that thing even works.
post #6 of 29 (permalink) Old 04-05-2010, 03:59 PM Thread Starter
Re: Cutting off
Has anyone ever had problems with thepart that swaps the to tanks over? And i was wondering should the fuel pressure drop when i get in the throttle? I would think it sgould stay the same or go up.
post #7 of 29 (permalink) Old 04-05-2010, 06:36 PM
Waljon's Avatar
Re: Cutting off
96 F250 ext cab 6637 3"down pipe 4" straight pipe ebpv delete ccv mod firestone air rite suspention
Waljon is offline
post #8 of 29 (permalink) Old 04-05-2010, 08:08 PM Thread Starter
Re: Cutting off
Well ive checked all that except the fuel bowl heater and still will not start. All the fuses look good to,just dont no which ones are what. which wire on the side is the fuel bowl heater?
post #9 of 29 (permalink) Old 04-05-2010, 09:09 PM
Waljon's Avatar
Re: Cutting off
next time it dies like that take a look inside the hpop res see if it is empty.
Waljon is offline
post #10 of 29 (permalink) Old 04-05-2010, 10:03 PM Thread Starter
Re: Cutting off
I havnt looked in it but the last time it did i put a guage between the line goin to the head and it had pressure,the guage only went to 500psi and it broke the guage so it had pressure. I need some diagrams or somethn one some of the wires to check cause its dead again and im just lost on what to check. Dont no what else to do.
