Starter Issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 01-22-2008, 04:03 PM Thread Starter
squeeks's Avatar
Starter Issues
My truck has been doing this for probably 6 months. What it will do is sometimes it will not crank over at all, i can hear the solenoid being activated on the passenger side fender well, and when the key is in the start position there is power on both terminals. What i usually have to do in order for it to start cranking is, 1: Get my girlfriend to turn the key, dont ask why it just seems to always work when she does it, 2: Wiggle the smaller 12 Gauge wire that goes to the solenoid on the starter itself, 3: Just let the truck sit and try it later in the day.
Lately i havent been able to get her to crank over no matter what i do, i get underneath the truck with the trunk in the start position and jump the terminals on the starter solenoid with a screw driver, the starter will turn over but not engage.
This is driving me nuts, i have a feeling that it is my starter solenoid, but any input would be appreciated.
1996 Ford F350 Regular Cab 5spd with the 7.3L PSD, 4x4, 35.5x12.5x16.5 All-Terrain T/A's, 3.73s', DIY Electric Reg Return Fuel Sys, 3" Downpipe, AFE Stg 2, 17* HPOP, IDM Mod, SB Con-O, Cat and Muffler Delete, AutoMeter NV Series Boost, Fuel Press. and Pyro, Autometer 3 Pod A-Pillar, TS Performance 6 Pos Chip. HPX Mod, 355,000 Miles
squeeks is offline
post #2 of 9 (permalink) Old 01-22-2008, 04:07 PM
All done now
Arisley's Avatar
Re: Starter Issues
That's what it sounds like to me.
Arisley is offline
post #3 of 9 (permalink) Old 03-01-2008, 06:17 PM
posbronc's Avatar
Re: Starter Issues
Did you ever figure out the problem? I am currently having the same/similar problem. Truck spun up and wouldn't stop spinning. After thitting the starter with a hammer, the starter doesn't do anything when I put the key in the start position... I hear the click, but no starter spin up...
03 F350 7.3 suprcab LB 6spd DRW Lariat 4x4 , Tow rig, just rolled 120,000miles- stock
posbronc is offline
post #4 of 9 (permalink) Old 03-01-2008, 11:14 PM
Old But Sexy
96 stroker's Avatar
Re: Starter Issues
i had the same problem and changed selnoid twice. did it yesterday and i relized it was the starter took it off and relized the wire and burnt from shorting out when tryin to start replaced the starter and starts like a dream now
96 stroker is offline
post #5 of 9 (permalink) Old 03-02-2008, 01:25 AM
Re: Starter Issues
Just replaced mine with a SD one AGAIN....third starter in less then 2 years...Bosche Remans....first time starter would not shut off second one just plain gave out no indication at all.
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #6 of 9 (permalink) Old 03-02-2008, 03:50 PM Thread Starter
squeeks's Avatar
Re: Starter Issues
I replaced the starter solenoid, then i had an issue where the starter would not dis-engage. I ended up just replacing the whole starter
squeeks is offline
post #7 of 9 (permalink) Old 03-07-2008, 03:38 PM
Re: Starter Issues
www.dbelectrical.com has good replacement starters and for a decent price.
pappy19 is offline
post #8 of 9 (permalink) Old 03-07-2008, 05:00 PM Thread Starter
squeeks's Avatar
Re: Starter Issues
yup, I got the high-tourque one, it really cranks over now
squeeks is offline
post #9 of 9 (permalink) Old 03-12-2008, 11:48 PM
What else?
smokyred's Avatar
Re: Starter Issues
The DB Electrical starter is sweet! It cranks over really fast, and makes starting when it's really cold out a breeze!
Dave
smokyred is offline
