e4od - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-03-2010, 03:31 AM Thread Starter
stoneykegonsa
e4od
Now that the warm weather has returned truck is not shifting from 1st to 2nd all the time some times it needs to be done manualy this is only a problem after trany has warmed up eany ideas thanks
stoneykegonsa is offline
post #2 of 5 (permalink) Old 04-04-2010, 05:28 PM
Demon Dually
speeddemon31176's Avatar
Re: e4od
Are you getting a flashing O/D light? If so then you need to have the truck hooked to a scanner. I would be suspect of a bad solenoid pack. I just put a new stage 3 trans in my truck and the company I bought it from had gotten a bad solenoid pack that they put in then when I put the trans in I had to have them send me two more until I finally got a good one. They ended up ordering a new one from ford for me. The reman company they were using named Recon has very poor quality control. I wouldn't get one from them. Moral of the story is that ypu either have a bad solenoid pack or an internal seal failure. The pack is easy to change. The seal would require a tear down though unless your valve body is sticking in which case you could swap out valve bodies.
speeddemon31176 is offline
post #3 of 5 (permalink) Old 04-04-2010, 05:36 PM
Re: e4od
my guess is valve body issues
02 f250
countryboyrob is offline
post #4 of 5 (permalink) Old 04-05-2010, 04:08 AM
blageurt's Avatar
Re: e4od
I also suggest you get your codes read... It does not necessarily require the OD light to flash in order to set a code. It probably is the solenoid pack as speeddemon suggested..
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #5 of 5 (permalink) Old 04-06-2010, 08:49 AM
tony from brooklyn's Avatar
Re: e4od
i had a similar problem last year.had to start out in 2nd gear then to drive.turned out to be the first gear shift solenoid.good luck.
'96 F-250 reg cab 2wd auto Posi 3:55s
1/4 mile 15.6 @ 88 mph
K&N air filter 70k
snow performance water/methanol injection
edge evolution,3" downpipe to 5" single stack
'00 F-350 reg cab 2wd dually bone stock needs a bed
124k
tony from brooklyn is offline
