Removing fuel bowl - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 04-02-2010, 02:13 PM Thread Starter
GilroyRacing's Avatar
Removing fuel bowl
I am going to be pulling my fuel bowl this weekend to replace some old O-Rings.
I bought my O-Ring kit from dieselorings.com.
Does anyone have a link to a write up, so I can prep myself on the removal process?
Also, I didn't order new hoses for the fuel bowl when I bought the O-Ring kit. Does anyone have part numbers from international, ford, napa, or advance auto so I can have them for this weekend?
Thanks for any and all help.
96FordF3507.3PSDCC, (Line X'd) bed, 4x4, 5 speed manual, 4.11 gears, 285/75/16 Cooper Discoverer ATP , 260,000 miles, 3-4" down pipe, 4" exhaust w/5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers, Garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
GilroyRacing is offline
post #2 of 14 (permalink) Old 04-02-2010, 02:45 PM
blageurt's Avatar
Re: Removing fuel bowl
It is quite simple on a F-series .... First you need to take off the intake "y" for access to the bowl bolts ( 2 ) then you disconnect the harness which also connects to the IPR so be carefull. Then you loosen the front drain hose ( if you have one) and the clamps on the PUMP side only. Disconnect the 2 return lines from the heads at the FPR before you remove you undo the mounting bolts . Undo the 2 filterbowl mounting bolts and pull it off gently. Make sure you DRAIN the filterbowl BEFORE you remove it.
I took my bowl with me to a o-ring shop partially dissassembled and he matched them up for me... As far as the hoses go I bought them at a hose place . You need 1 ft each of 3/8 and 5/16 300 psi fuel injection hose ...also buy the good clamps ( also for fuel injection). You then take off the little hoses and cut new ones to match from your 1 ft pieces of each. On reassembly attach all hoses to the filterbowl first and tighten them since you will not be able to tighten them after you install the bowl.. re-attach the return lines at the FPR and do not overtighten them since they are compression type...
Hope this helps...
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #3 of 14 (permalink) Old 04-02-2010, 04:07 PM Thread Starter
Thanks for the wrie up, I went ahead and ordered the high temp hoses and clamps from dieselorings.com
post #4 of 14 (permalink) Old 04-06-2010, 03:14 AM Thread Starter
I got the fuel bowl removed, what a nasty mess that was with all the fuel that was leaked out.
Its a good thing I went ahead and ordered the new hoses as the old ones were old and starting to crack up.
My only question is, that when I pulled the fuel bowl I noticed on one of the wires the little weather protector that keeps the moisture out has start to desinigrate, I guess from the fuel. I am thinking that the wire is for the fuel bowl heater. Where can I get a new wire harness at?
post #5 of 14 (permalink) Old 04-06-2010, 03:23 AM
itsallinthestroke's Avatar
imo you dont need the fuel bowl heater. i live in northern indiana and never had a problem with mine. not to say that some day i wont hook it up again but just my 2 cents. also I have read a number of times that they tend to short out and not work anyways
96 F250 x-cab 4X4 250,000 mi, 5in straight pipe, ts 6 pos. with house tunes, jasper rebuilt trans, tymar intake, glowshift gauges, soon to have coolant filter
itsallinthestroke is offline
post #6 of 14 (permalink) Old 04-06-2010, 04:27 PM Thread Starter
My heater element is broke. How do I remove it and replace it?
post #7 of 14 (permalink) Old 04-06-2010, 11:10 PM
blageurt's Avatar
You need to remove the Stand pipe .... I used a basin wrench but you a can use a crow foot socket /wrench ...remember it is reverse thread and is plastic AND costs $ 80 bucks so be very carefull
blageurt is offline
post #8 of 14 (permalink) Old 04-07-2010, 01:57 AM Thread Starter
Fuel bowl has been removed, and all orings and hoses replaced.
I re-installed it, and no leaks!
Thanks for all your help blageurt.
post #9 of 14 (permalink) Old 04-07-2010, 03:42 AM
Patrick Feeley's Avatar
Here's the part number for the fuel bowl wiring harness (its about $60 though ... they've gone up!):
Fuel Filter Housing Wiring Harness
(Ford) F7TZ-9S277-AA
Cheers!
Patrick Feeley is offline
post #10 of 14 (permalink) Old 04-09-2010, 07:01 AM Thread Starter
Thanks Patrick.
