Napa/Wix oil filter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 04-02-2010, 01:27 PM Thread Starter
GilroyRacing's Avatar
Napa/Wix oil filter
I just ordered a Napa/Wix 1734XE oil filter for my truck.
I was wondering if anyone else has used it before?
96FordF3507.3PSDCC, (Line X'd) bed, 4x4, 5 speed manual, 4.11 gears, 285/75/16 Cooper Discoverer ATP , 260,000 miles, 3-4" down pipe, 4" exhaust w/5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers, Garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
GilroyRacing is offline
post #2 of 15 (permalink) Old 04-02-2010, 01:30 PM Thread Starter
Re: Napa/Wix oil filter
PARTS DETAIL
Principal Application: Synthetic Media Version Of 51734
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Glass
Height: 8.122
Outer Diameter Top: 4.266
Outer Diameter Bottom: Closed
Thread Size: 1 1/2-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 4/75=10/30
Burst Pressure-PSI: 200
Max Flow Rate: 28-30 GPM
Nominal Micron Rating: 10
post #3 of 15 (permalink) Old 04-02-2010, 02:06 PM
99whitetanpsd's Avatar
Send a message via AIM to 99whitetanpsd Send a message via Yahoo to 99whitetanpsd
i use mobile 1
E99 f250 4x4 CC SB (sold)
7.3L powerstroke
292hp 658tq
[email protected] 1/8 mile
06 ram 2500 4x4 qc sb
5.9L 24V cummins
Originally Posted by Deereman4020 View Post
Fuk D-maxes I'll get a cummins before a D-max.
99whitetanpsd is offline
post #4 of 15 (permalink) Old 04-02-2010, 02:09 PM Thread Starter
I usually do too, I bought this one to try it out, and am curious if anyone else is using it.
How does it compare to the Mobile 1, K&N, Pure 1 filters?
post #5 of 15 (permalink) Old 04-02-2010, 02:24 PM
14psd's Avatar
It matches the white on your truck. Sorry someone on here had to be a smartazz
Todd
__________________________________________________ _________________________________
'95 F-350 daully, Super Cab, 230K+ miles, 2 wd, automatic, Bean's stage 1, shimmed fpr, 3" down pipe, superchip, gauges boost, EGTs, trans, and volts, missing Kitty & muffler, Homemade tymar set-up, HPX mod, CCV mod, and air bags in the rear
14psd is offline
post #6 of 15 (permalink) Old 04-02-2010, 02:28 PM
hit n miss
Peroni's Avatar
I've used the Wix XE version since the day I did my first oil change. Never had a problem and they've worked great. Fleet Filter has them for about $24, can't afford them otherwise as Napa lists them for $44ea!
97 Green F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, electric fuel, CCV mod, 6.0 fan, tru-cool 4739, Swamps 175/30% injectors, stage I Stealth pump, LASB turbo, Spearco 6.0 cac, live tuned 442hp/860tq.
Peroni is offline
post #7 of 15 (permalink) Old 04-02-2010, 02:48 PM Thread Starter
HAHA yep thats why I bought it
post #8 of 15 (permalink) Old 04-02-2010, 02:49 PM Thread Starter
Yep, thats where I ordered mine. Ordered a fuel filter, oil filter, and air filter.
post #9 of 15 (permalink) Old 04-02-2010, 02:51 PM
blageurt's Avatar
I sure you will be fine ... I only use Motorcraft and or Fram
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #10 of 15 (permalink) Old 04-02-2010, 03:06 PM
tank's Avatar
I have been wanting to run this filter for a while now. I haven't used it as of yet. I worry that it might plug up to quick since it filters so fine. It filters down to 10 microns where a stock filter is rated down to only 20 microns. If I remember right the amsoil bypass filter is only rated down to 15 microns.
Please keep us informed of how it goes for you. I'd love to be able to keep my oil 10 microns cleaner than I do now.
E99 F250 CCSB 6 pos chip Gearhead Auto
Swamps 250/80 hybrids ARP head studs DI pushrods Comp 910s Adrenalin hpop ceramic coated 38r and up pipes complete fuel system + regulated return water/meth full built trans PI converter JW vb afe2 intake and afe bladerunner 3" intakes 4" tb exhaust 6.0 tc pmt 1 boost egt + scangauge
tank is offline
