Tips on removing rusted on drums? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-01-2010, 04:11 AM Thread Starter
ianjadkins's Avatar
Went to remove the drums to see what shape the rear brakes were in. Been having some rear hopp and think its warped drums. The drums are rested on. Tried to hammer on the maiting surface between the studs. No luck. Any ideas?
Thanks,
Ian
95 Extended cab Long Bed XLT
Dana 60
Tymar Intake
Sport Comp Gauges
FPR Shim
3" Dp - 4" Exhaust
ianjadkins is offline
post #2 of 11 (permalink) Old 04-01-2010, 04:16 AM
oil burner
tughill283's Avatar
Re: Tips on removing rusted on drums?
get really pissed off and beat the crap out of em with a big sledge hammer,if that dont work break out the torches!
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #3 of 11 (permalink) Old 04-01-2010, 04:20 AM
<---new toy
DPS0925's Avatar
Take a can of wd-40 or something and spray the adjuster down. Back the shoes off , by the way spray around the stud holes too. then let it set alittle while, drink a beer. then it should come right off.
DPS0925 is offline
post #4 of 11 (permalink) Old 04-01-2010, 04:25 AM
Demon Dually
speeddemon31176's Avatar
I use a rubber shot peen hammer that is about a five pounder. I hit the edge of the drum all the way around the drum several times with a decent amount of force. Then I hit the corner edge around where the drum rounds over from the mating surface to the shoe contact area. Then hit the mating surface area to straighten it out. It almost always comes off by wiggling it forward off the shoes then.
speeddemon31176 is offline
post #5 of 11 (permalink) Old 04-01-2010, 03:02 PM
Cratos's Avatar
Spray BP blaster around where the hub and drum meet up let it sit a while, then back off the adjusters all the way. Then let the beating begin!
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #6 of 11 (permalink) Old 04-01-2010, 05:12 PM
OEM Moderator
Tom S's Avatar
If you have a curved end wrecking bar you can apply pressure to help pop off the drum by prying off the leaf spring while hitting it with a hammer. I little grease on that lip helps to prevent that issue once you get it cleaned up.
Tom S is offline
post #7 of 11 (permalink) Old 04-01-2010, 05:15 PM
A slide hammer with a hook end will get it moving too. Its will make you curse for sure.
thewolf is offline
post #8 of 11 (permalink) Old 04-01-2010, 05:48 PM
F350 FF's Avatar
I had to use a spud bar and sledge plus a big screwdriver at the same time, turns out my old drums were worn really bad from the P.O. and had a big lip inside catchin on the shoes not to mention the rust as well.
matt z
Have - 95' F350 PSD, 2WD supercab dually, E4OD, 4:10's, Tymar intake, 3" DP, Bully Dog 4" cat back, CPR fuel bowl delete / E-Fuel, Adrenaline Oil
Want - ZF5, Flatbed
F350 FF is offline
post #9 of 11 (permalink) Old 04-01-2010, 08:25 PM
ohh bee ess
202wagon's Avatar
Bingo! The key is to back off the brakes...if you don't, it'll never come off because the shoes will be caught up against the rust lip on the inside of the drum (outer edge).
1997 F-250HD XLT ECLB 4WD, built E4OD, 4.10 LS, baby Swamp's, MPRP 4" turbo back w/ 3" dp, S&B intake, Edge Evo (for now...yes I know), 167k
*SOLD*1997 F-250HD XLT ECLB, 4WD, BTS E4OD, 3.55, MBRP 4" turbo back w/ 3" dp, S&B intake, 6 position chip w/ BTS tunes, Auto Meter pre-turbo py
Leaving a carbon footprint as big as Sasquatch !
202wagon is offline
post #10 of 11 (permalink) Old 04-02-2010, 08:07 AM Thread Starter
ianjadkins's Avatar
I know to back off the brakes, but it was so rusted on that even some hammer beatings wouldn't budge it. I just said screw it and bought all new rear brakes today, that way if I dent then while giving them a massive beating it won't matter. I will hit them with a penetrating oil a few times in the morning then comense the beatings!
Dana 60
Tymar Intake
Sport Comp Gauges
FPR Shim
3" Dp - 4" Exhaust
