temp control - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-30-2010, 04:53 PM Thread Starter
Building Farmboy Monster
ttford07's Avatar
temp control
Ive got a 95 reg cab, and no matter where i turn the thermostat it is stuck on blazing hot. The vent switch works though, any ideas? maybe just bad switch?
2000 psd 7.3=S366, Hybrids, Twin Hpops, AirDog, Beans Tunes, 6spd conversion
660Hp 1394Tq Fuel Only!!!
593hp-1219tq April 16, 2011 OH YeaH!!
Spraying to get horsepower is kinda like paying a hot chick to go on a date with you. In the end what does it prove because you wont always have it.
ttford07 is offline
post #2 of 5 (permalink) Old 03-30-2010, 09:16 PM
Demon Dually
speeddemon31176's Avatar
Re: temp control
Sounds like the plenum isn't moving like it should. Get down on the passenger floor and feel the heater box and change the temp setting and see if you feel the plenum door move.
speeddemon31176 is offline
post #3 of 5 (permalink) Old 04-01-2010, 03:10 PM
Cratos's Avatar
Re: temp control
check the vac line on the pass fender it ie a small with hard line .mine it flaking apart so I covered it with rubber line.
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #4 of 5 (permalink) Old 04-01-2010, 06:55 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Re: temp control
I did the same on mine
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #5 of 5 (permalink) Old 04-02-2010, 02:44 AM Thread Starter
ttford07's Avatar
Re: temp control
Alright thanx guys ill take a look
ttford07 is offline
