no wait to start light and wont start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-30-2010, 04:52 AM Thread Starter
dbart's Avatar
Unhappy no wait to start light and wont start
Got a 96 f250 and the went to move out of garage and wont start. Wait to start light in cab not working, replaced the relay,glow plugs, found #3 and 31 fuse blown and replaced them still no start. can jump across glow plug relay and start but when wire gets hot and comes off truck dies any ideas. any body thanks.
dbart is offline
post #2 of 10 (permalink) Old 03-30-2010, 05:10 AM
Patrick Feeley's Avatar
Re: no wait to start light and wont start
Check underhood fuse #22 (30A maxi: middle row, closest to the engine). If it has blown, your fuel heater has shorted. Disconnect the fuel heater element via the external connection (funny squarish-looking plug) on the driver's side of the fuel bowl or the internal connection (drain bowl, remove filter lid and filter ... my favorite way) from inside on the driver's side. Replace the fuse and see what happens. Cheers!
Patrick Feeley is offline
post #3 of 10 (permalink) Old 03-31-2010, 02:53 AM Thread Starter
dbart's Avatar
Thanks Patrick unpluged the fuel heater and fuse good still no wait to start light and wont start. where does the glow plug relay get its power from the battery and does the key activate the other two red wires because the only one hot is the black/ blue tracer none of the other wires have power.
dbart is offline
post #4 of 10 (permalink) Old 03-31-2010, 02:54 AM Thread Starter
dbart's Avatar
And OTC machine will not communicate with ECM Thanks
dbart is offline
post #5 of 10 (permalink) Old 03-31-2010, 04:19 AM
Do you have power at the cig lighter? OBDII port gets power on same circuit. Glowplug relay coil gets power through #22. Other side (big wire) gets it from 2 fuse links. PCM gets power through underhood fuse #9 via the PCM power relay (one of the square relays in the underhood fusebox). Cheers!
post #6 of 10 (permalink) Old 04-01-2010, 02:33 AM Thread Starter
dbart's Avatar
cig lighter has power #22 fuse good, #9 fuse good, PCM relay good, I gues i will replace the ECM running out of things to replace.
dbart is offline
post #7 of 10 (permalink) Old 04-01-2010, 02:37 AM Thread Starter
dbart's Avatar
oh does the diode have any thing to do with the power to the glow plug relay because it does not have any continuity.
dbart is offline
post #8 of 10 (permalink) Old 04-01-2010, 04:30 AM
Demon Dually
speeddemon31176's Avatar
I would verify that you have power on both sides of each fuse both in the power distribution box under the hood and in the fuse panel under the dash first before spending the money on a new PCM. I would also verify that the wait to start light bulb is not just burnt out. You could also have faulty wiring, a bad ignition switch, or a multitude of other issues that could be causing your problem. What wire are you jumping out that is getting hot? You state when this wire comes off the truck dies, which wire is this and where is it located? It sounds like an ignition switch issue. If you need Ican give you the colors of the wires at the ignition switch that should be hot in the run position and you can check them with a meter to verify whether or not they are getting power.
speeddemon31176 is offline
post #9 of 10 (permalink) Old 04-03-2010, 02:42 AM Thread Starter
dbart's Avatar
Thanks Patrick and Speeddemon for all your help. it looks like the shorted glow glug wires fried my PCM replaced it all running fine now. Thanks for everything dbart
dbart is offline
post #10 of 10 (permalink) Old 04-04-2010, 05:21 PM
Demon Dually
Well glad you got it running again man. That sucks that it took out the pcm though.
