transmision help. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-29-2010, 05:20 AM Thread Starter
transmision help.
I have a '97 F350 with the e4od trannsmission, and i want to swap it to a 6 speed stick shift, is there a kit available for this??
gear_head15 is offline
post #2 of 8 (permalink) Old 03-29-2010, 05:25 AM
Empty Wallet
96bullhauler's Avatar
Re: transmision help.
Ive never swapped transmissions in one of these trucks, especially something like a superduty trans into an OBS, but ive done several swaps on cars. Keep in mind all of the little pieces parts youll need aside from the obvious (pilot bearing, block plate, interior trim, possible computer tuning to turn off transmission MIL's, etc.). Stuff can add up quick.
96bullhauler is offline
post #3 of 8 (permalink) Old 03-29-2010, 04:40 PM
Strokin'
maybe this will help..
ZF6 Speed Swap into a 97 OBS - Powerstroke Nation
94' F-250 PSD, Reg. cab, 4x4, ZF-5, K&N, 3" DP, 5" Exhaust.
93' F-250 SCLB, 4x4, Gas.
88' F-350 460 Wrecker. Lots of LED's.
The Bank doesn't own my trucks.
jakeloney is offline
post #4 of 8 (permalink) Old 03-29-2010, 04:43 PM
Crazy Canuck's Avatar
i know it is better to have a donar vehicle for all the little stuff, brackets and such like the second post said. i have also done an automatic to standard on a 78 f150.
2011 F350 CC Dually, Lariat, ultimate package PSD, lock pick, line x, weather guard x box. Pic in avatar.
2000 xcab F250 PSD 4x4 not even close to stock, broken Feb 2011 (collision, write off)
Crazy Canuck is offline
post #5 of 8 (permalink) Old 03-29-2010, 05:04 PM
bobvillaoftn's Avatar
PM INTPSTROKE96 he done one and i asked him a lot about it and didnt find it feasible for me. good luck.
05 f350 CCLB 4x4 delete and sct x4 thanks to innovative
Originally Posted by RedSmokey View Post
Sh*t in a box (litterally) and write "Will give you 200+ hp, just add to your fuel" on the box and give it to him. Then ask him if he still believe's everything thats written on a box...
Originally Posted by bruce51d View Post
if you can blow up a 7.3 just imagaine what you would do to a 6.0
bobvillaoftn is offline
post #6 of 8 (permalink) Old 03-29-2010, 05:06 PM
Here is a list of things that had to be changed that did not just direct bolt up.
Move trans. crossmember back, slot holes and fab a mount for the pass. side.
Push the floorboard up at the back of the trans.
Shorten rear drive shaft and change the flange to match the flange on the transfer case.
Lengthen the front drive shaft, take the cv out of it and put the flange you take off the rear on it.
Move the transfer case skid plate back.
Install a trans. cooler and run rubber line.
just found that from him. there might be some other stuff but like i said PM him and he'll let ya know.
post #7 of 8 (permalink) Old 03-29-2010, 05:39 PM
bryan rittenhouse's Avatar
im getting ready to do this to my truck ill keep you posted on how hard it will be but from what ive done and seen so far its not gonna be bad.
Bryan
2001 GMC 2500HD duramax
03 Chevy Front Clip, Custom Fuel System, Tuned with EFI Live. Just a work truck.
HRT Performance
Mikes Diesel Performance
bryan rittenhouse is offline
post #8 of 8 (permalink) Old 03-29-2010, 06:20 PM
i also recall now that the tunnel has to be "massaged" for the new tranny to fit, also i believe you have to use the transfer case from the 6 spd if its 4wd and not your 5 spd one.
