No Ohm reading on GP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 11-05-2019, 07:39 PM Thread Starter
Hello,
I am new to the forum and also new to working on a big diesel truck. My 1996 F350 has a hard time starting in the morning and i read up on this and also did some checks already.
pretty sure my GPR needs to be replaced since it works better when I jump the relay. I wanted to test my glow plugs with a multimeter and when I put it on the Ohm setting ground the negative and touch the outer pins with my positive I get no reading. tried different ones and even the ones on my parts truck and no reading. Any ideas what the reason for that could be? ****ty multimeter?
Thanks for your input
staema is offline
post #2 of 11 (permalink) Old 11-05-2019, 07:44 PM
Blue-Truck-Nut97's Avatar
Re: No Ohm reading on GP
Could be, touch the leads together and see if it goes to 0.
Blue-Truck-Nut97 is offline
post #3 of 11 (permalink) Old 11-05-2019, 07:47 PM Thread Starter
Did that. First, I get different readings but after a bit, it will show 0.00.
staema is offline
post #4 of 11 (permalink) Old 11-05-2019, 07:49 PM Thread Starter
Think it would not make sense but do I need to have the ignition on to get a reading?
staema is offline
post #5 of 11 (permalink) Old 11-05-2019, 08:03 PM
Not for that part of the test. Are you testing at the valve cover side or the wire side?
post #6 of 11 (permalink) Old 11-05-2019, 08:08 PM
alleged moderator
tjctransport's Avatar
no. good glow plugs only read .5 to 1.5 ohms so you need to set it very low to get a reading. if the truck starts when you jump the relay i would say the glow plugs are good for now.
with cold engine,put volt meter negative to ground wire and probe gpr terminals with positive wire with meter on 20 volt range, you should see around 12 volts on 3 of the 4 terminals. the one large terminal with no power is the one going to the glow plugs.
now have a helper turn key to run and probe the one that had no power. if it is now hot, the relay is good. if still no power, the relay is bad.
tom
tjctransport is offline
post #7 of 11 (permalink) Old 11-06-2019, 08:43 PM Thread Starter
Got some readings today on the GP`s which almost all are to low. still some with no reading so i guess i will just order some new ones. not the most expensive purchase anyways. Thanks for your help
staema is offline
post #8 of 11 (permalink) Old 11-06-2019, 10:56 PM
alleged moderator
motorcraft ZD-11 glow plugs ONLY
all other brands are pure crap and some burn out on the first use.
tom
post #9 of 11 (permalink) Old 11-06-2019, 11:20 PM
Bugman's Avatar
When you pull your valve covers on the ones that are not reading check them then. You could have some bad wiring.
Also if you didn't think of it replace all of them at the same time. Saves headaches later.
Bugman is offline
post #10 of 11 (permalink) Old 11-07-2019, 02:43 AM
Patrick Feeley's Avatar
If you are going to replace the plugs, get a 1/4"-drive 10mm deepwell socket and an extension. It gives more clearance getting in between the rockers. Cheers!
Patrick Feeley is offline
