Vibration that is RPM related .. or so it seems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-20-2019, 08:48 AM Thread Starter
Joshua Barr's Avatar
Problem:
When cruising down the road approaching 1500 rpms in any gear you start to hear a faint howling sound and maybe even a buzzing like vibration in the floor and gas pedal. As rpms increase to 2000 it gets worse ( louder ). Once up to 2000ish rpms it fades maybe just a little but still very noticeable. This only happens when under load/throttle pedal down. If I get up to speed and cruise somewhere in the 1500-2000 rpm range and let off the throttle and coast the howling/buzzing goes away completely. I CAN recreate this at any speed.
I thought maybe it was the down pipe rubbing the firewall again but I dont think this is the case anymore after looking around at it again today. Unless there is significant movement while motor is under load and pushes it into it or the transmission or something. There is some space between the pipe and surround equipment but not very much at all.
Notable things:
Transmission was rebuilt 2.5k miles ago at reputable shop by previous owner so I don't know if this is a new thing or not.
EGBPV is still in place but no leaks and works as it should when cold
It runs great and will run with this but it is irritating after awhile
Joshua Barr is offline
post #2 of 5 (permalink) Old 10-20-2019, 03:19 PM
Re: Vibration that is RPM related .. or so it seems
Josh,
I'd check all the U-joints and bearings in the rear drive line to start with. Worse case would be something like this poster: https://www.powerstrokenation.com/fo...iveline-2.html
Cj
1997 F350 CCLB 7.3, Eaton Fuller RTO-6610, 4x4, 3.54, otherwise stock
cjfisher is offline
post #3 of 5 (permalink) Old 10-21-2019, 06:47 AM
Blue-Truck-Nut97's Avatar
Since the transmission has been out, I would advise checking your motor mounts. The 7.3 mounts can move forward and back, at which point metal to metal contact occurs, forward and rearward movement is prevented by the transmission mount.
Sometimes when changing the transmission the engine gets slid one way or the other, and when the motor mounts aren't put back to center, all kinds of funky noises happen.
Blue-Truck-Nut97 is offline
post #4 of 5 (permalink) Old 10-21-2019, 10:12 AM Thread Starter
I'll have a look today! Thanks for the advice. I was kind of thinking something like that may cause an issue but never really pursued it.
post #5 of 5 (permalink) Old 10-31-2019, 06:52 AM
Id also check to see if any of the firewall heat shield is touching the Down Pipe, one of my trucks took me a while to figure that it was just touching intermittently. Actually rubbed a hole in the DP, that heat shield is some robust material.
Cheers,
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
