1996 F250 D50 TTB Spindle confusion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-19-2019, 06:56 PM Thread Starter
Hey everyone!
First post here and I'm needing some help. I have a 1996 F250 with a D50 TTB 4600lb front GAWR 4XD with manual hubs. I'm in the process of replacing ball joints with the XRF units, Timken bearings, and new spindles now as well. The problem is I'm having trouble locating the correct spindle nut parts and spindle. I've attached the only spindle retention nut/clip holding the entire thing on. I either want to locate the same as what I have for replacement, or preferably replace with a more traditional 4 slot spindle nut. Can anyone point me in the right direction? I've attached pictures below of what came on the vehicle. I'm pretty frustrated, but would be happy with knowing I can put something such as these on there, even though they're a bit overkill.
baconrocket is offline
post #2 of 3 (permalink) Old 10-19-2019, 07:02 PM Thread Starter
Re: 1996 F250 D50 TTB Spindle confusion
Edit: Looks like someone converted from auto to manual hubs without using the manual specific spindle nuts, etc. Hopefully I can still find what I need.
post #3 of 3 (permalink) Old 10-20-2019, 03:37 AM
Patrick Feeley's Avatar
Not sure this helps, but I'm fairly certain this is what was used on mine when it was converted to Warn manual hubs: "Locking Hub Spindle Nut Conversion Kit - 32721". Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
