battery indicator issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-17-2019, 03:30 PM Thread Starter
I have a 97 F 250 with a 7.3. I am getting the battery indicator light in the dashboard display panel. My first thought is that I have an alternator problem but notice that the light comes on when I let off the throttle and sometimes at idle. Any thoughts?
woffie50 is offline
post #2 of 4 (permalink) Old 10-17-2019, 10:44 PM
alleged moderator
tjctransport's Avatar
Re: battery indicator issue
have the alternator tested for output at idle when the light is on. also check the plug going into the alternator. it may just be loose.
tom
tjctransport is offline
post #3 of 4 (permalink) Old 10-18-2019, 03:00 PM Thread Starter
I had the alternator tested, it was bad. Replaced.
woffie50 is offline
post #4 of 4 (permalink) Old 10-18-2019, 03:01 PM Thread Starter
Thanks for your advice. I'll watch for that if I can remember 10 years from now when it happens again.
woffie50 is offline
