battery indicator issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-17-2019, 03:22 PM Thread Starter
I have a 97 F-250 Heavy Duty with a 7.3. I am getting the picture of a battery in the instrument panel sometimes. I was thinking it may be the alternator but noticed that it comes on when i let off the throttle, no matter what speed the engine is turning. Any Ideas?
woffie50 is offline
post #2 of 6 (permalink) Old 10-17-2019, 07:53 PM
Patrick Feeley's Avatar
Re: battery indicator issue
What's the voltage gauge doing at the same time? Cheers!
Patrick Feeley is offline
post #3 of 6 (permalink) Old 10-17-2019, 08:39 PM Thread Starter
Voltage gauge holds steady at about 14 V.
woffie50 is offline
post #4 of 6 (permalink) Old 10-18-2019, 02:00 AM
Not uncommon for the square plastic wiring harness plug in top of alternator to wear the blade connector via vibration. Fix is to pull plug out and with needle nose pliers pinch the female connector slightly, re install.
Cheers,
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #5 of 6 (permalink) Old 10-18-2019, 03:03 PM Thread Starter
Thanks for the advice. I had the alt tested. It was bad and replaced it.
woffie50 is offline
post #6 of 6 (permalink) Old 10-18-2019, 08:15 PM
College Student
My truck did the same as yours occasionally for about a year or more. The battery light would just come on randomly or when coasting. Thought it was the plug to the alternator, fiddled with it and it stopped for a while then came back. Finally it became more frequent and then just stayed on. The voltage meter would flicker every time.
Turns out that the wire that funs from behind the battery box, then under the batter and coolant container to the alternator had rubbed on the hard bend and eventually shorted it self. Soldered the wires back together and it has worked since.
95 Auto. 4.10 gears. SCLB. Baby Swamps Injectors, TS-6 chip with swamps tunes, DIY E-Fuel. AFE MaxFlow. Glowshift trans, pyro, and boost. 6.0 IC KC TP38R. Converted EBPV to exhaust brake.
Cumminsdurastroke is offline
