computer trouble - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-26-2010, 10:47 PM Thread Starter
shake, rattle, n roll!
computer trouble
got a 96 ps with 0605 and 1668 codes and it runs ruff if u mash th pedal = more than a quarter of they way down other wise it runs fine idles good and while its cold it runs fine it just happens when it warms up idk
smokegrinder is offline
post #2 of 10 (permalink) Old 03-27-2010, 03:36 AM
Patrick Feeley's Avatar
Re: computer trouble
0605 is Internal Control Module ROM Error and 1668 is PCM - IDM Diagnostic Communication Error. I guess it could be a PCM problem, especially with 0605 (can you clear the codes and rerun the diagnostics?), but ... Do you have problems restarting it when warm? You could have Injection Pressure Regulator (IPR) valve o-rings on their way out or even bad injector o-rings (does it use any oil?). The warm oil will more readily bypass the o-rings than cold, thicker oil. Cheers!
Patrick Feeley is offline
post #3 of 10 (permalink) Old 03-28-2010, 01:05 AM Thread Starter
yea i cleared th codes twice and they came back it doesnt use much oil bout 2 quarts every 5000 miles and no it starts fine wen its warm
post #4 of 10 (permalink) Old 03-28-2010, 05:00 AM
The pinpoint test in the service manual is fairly easy for the 0605 code:
AG1 DIAGNOSTIC TROUBLE CODE (DTC) 0605: PCM ROM FAILURE
DTC 0605 exists only when there has been an internal failure of the powertrain control module (PCM).
Rerun Scan Tool Diagnostic Test.
Is DTC 0605 retrieved?
Yes
REPLACE PCM.
No
System OK. RERUN Scan Tool Diagnostic Test to see if there are any other stored DTCs.
Cheers!
post #5 of 10 (permalink) Old 03-28-2010, 07:54 PM Thread Starter
thanks for the help bud i will get me one and put it in n c what happens where is th best place to buy one at?
post #6 of 10 (permalink) Old 03-29-2010, 04:39 AM
I got one at RockAuto for $115 plus $75 refundable core. Cheers!
post #7 of 10 (permalink) Old 03-30-2010, 03:45 AM
Wondering can the PCM be bad and not show any codes. My truck is doin similar to that to. Just dont give no codes.
fastmust88 is offline
post #8 of 10 (permalink) Old 04-02-2010, 02:31 AM Thread Starter
idk bud
post #9 of 10 (permalink) Old 04-02-2010, 03:56 AM
So did u ever find your problem?
post #10 of 10 (permalink) Old 04-12-2010, 12:05 AM Thread Starter
i found out that my ts chip that i had on my truck was cuasing that code to come up but th truck missing.... its th injectors time for a new set
