Which type of oil to use for my 96 F250 7.3? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #1 of 17 (permalink) Old 10-09-2019, 01:59 AM Thread Starter
Abraham1996's Avatar
Hey everyone, I just recently bought a 1996 Ford F-250 7.3 powerstroke and Im going to do an oil change this week. I’ve researched on many forum and some say that Rotella is the best but which Rotella should I us T4 T5 or T6? I live in Los Angeles. I’ve also heard that the Motorcraft Diesel motor oil is good too.
Abraham1996 is offline
post #2 of 17 (permalink) Old 10-09-2019, 02:17 AM
Bugman's Avatar
Re: Which type of oil to use for my 96 F250 7.3?
I've ran Valvoline 15w40 in my truck since it was new. Right now it is Valvoline Premium Blue 15w40, if I was to use a synthetic it would be their Premium Blue Extreme 5w40
Sent from my SM-J737V using Tapatalk
Bugman is offline
post #3 of 17 (permalink) Old 10-09-2019, 04:05 AM
College Student
All my truck has ever seen is Delo 10w40 in the summer and 5w30 in the winter....
Never had a complaint nor has my truck.
95 Auto. 4.10 gears. SCLB. Stock besides Baby Swamps Injectors and TS-6 chip with swamps tunes. AFE MaxFlow. Glowshift trans, pyro, and boost. 6.0 IC KC TP38R. Converted EBPV to exhaust brake.
Cumminsdurastroke is offline
post #4 of 17 (permalink) Old 10-09-2019, 12:32 PM
alleged moderator
tjctransport's Avatar
same here. valvoline premium blue. used to be called all fleet plus.
it goes in everything i own. the 88 diesel has 495,000 miles on it, the 02 diesel has 195,000 on it, the 2004 gas engine has 254,000 on it, and 2014 has 114,000 on it. none have ever been opened up.
you can talk to different people and hear stories about different oils. everyone has their preference.
as long as it is diesel rated, you are golden.
tom
tjctransport is offline
post #5 of 17 (permalink) Old 10-09-2019, 11:12 PM
LateToTheDesert's Avatar
That’s a good looking truck you bought if it’s the one in your profile picture. I’ve been following the previous owner on IG for a while now.
I use Rotella T5 15w-40.
I’m sure the Motorcraft is a good oil too since ford recommends using it.
But I’ll stick with the T5 for me.
As long as you keep the maintenance up it will be fine. These motors like clean oil.
LateToTheDesert is offline
post #6 of 17 (permalink) Old 10-10-2019, 12:34 AM
Project Shamu
Lt.Dan's Avatar
I used rotella for a while until I started doing oil analysis, then I switched to delo isosyn 15w-40, and have had some better results.
Everybody has their preference
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #7 of 17 (permalink) Old 10-10-2019, 12:17 PM
RustbeltJohnny
Rustbeltjohnny's Avatar
Garage
I use Amsoil Heavy Duty/Marine Diesel Oil 15w-40 with a 12 TBN content. It is recommended for any diesel prior to 2007. Im a dealer so I get that wicked discount. The stuff out preforms anything I have used prior to it including Shell Rotella, and prior to that I used Mobil. I also use Donaldson filters or WIX and in a pinch Ill nab Motorcraft.
Get out your pooper scoopers, cuz these suckas are talkin ####.
Rustbeltjohnny is offline
post #8 of 17 (permalink) Old 10-10-2019, 03:14 PM
alleged moderator
no disrepect to you Johnny, but after seeing what amsoil did to three engines i would not recommend it for use in anything................ and neither will the amsoil dealer who got screwed by amsoil when they told him to pound salt.
Bugman, Lt.Dan and Dustybumpers like this.
tom
post #9 of 17 (permalink) Old 10-10-2019, 07:26 PM
don't play well w others
Dustybumpers's Avatar
I use delo isosyn 15w-40, used to use Rotella
I Agree with the window licker, I would never use amsoil. That would be like pouring dish soap in my motor
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
post #10 of 17 (permalink) Old 10-10-2019, 08:17 PM
Rotella T4 15w-40 summer 10w-30 winter and Donaldson DBL 7405 filter, which is much larger than stock, usually swap out at 7,000-8,000 kms.
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
