Before replacing the IDM, check all you valvecover connections for evidence of melting or burning, and oil in the connectors. Remove the oil cap and sniff it. Does it smell like burned electrical insulation? Also, is the CEL illuminated? Does it have a chip ? Cheers!
Ok idm is good check the harness all good it's still doing same . It starts right up and as long as I press the gas pedal for about a minute it goes away and runs fine but does it every time on start up hot or cold.
