1995 7.3 no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 09-13-2019, 09:08 PM Thread Starter
1995 7.3 no start
Should the engine oil pressure gauge rise when cranking for awhile, if not would that cause a no start. Where can I plumb in a mechanical gauge. Plus where do they hide the obd2 connector, can’t find it under the dash anywhere
Cinahcem is offline
post #2 of 8 (permalink) Old 09-13-2019, 10:08 PM
Bugman's Avatar
Re: 1995 7.3 no start
The stock oil pressure gauge is just a idiot gauge and might or it might now register after cranking for a while. But it will not cause a no start by itself.
You can plumb in a mechanical one down at the port on the oil cooler header just above the oil filter or where the stock sender is at on the high pressure oil pump.
The OBD II connector is under the ash tray, but remember that 99% of the code readers out there can not read codes from our trucks due to Fords propriety codes that is sends out.
As for your not starting, do you get the wait to start light when you turn the key on?
Also if the is no low pressure oil it won't feed the high pressure oil pump which the injectors require. You can pull the plug on the high pressure oil reservoir and see what the level is, it should be at or near the top.
Bugman is offline
post #3 of 8 (permalink) Old 09-13-2019, 11:42 PM Thread Starter
So I plumbed in a mechanical gauge and I have oil pressure so that’s good. The wait to start light does not come on, and my AE scanner won’t connect to the vehicle. So what does it mean when that light doesn’t come on?
Cinahcem is offline
post #4 of 8 (permalink) Old 09-14-2019, 12:26 AM
Blue-Truck-Nut97's Avatar
Check your fuses. I'm suspecting that you may find fuse #22 under the hood blown. If so, unplug the fuel bowl heater, and replace the fuse. Then see if it starts and runs, and your scanner works.
Blue-Truck-Nut97 is offline
post #5 of 8 (permalink) Old 09-14-2019, 12:37 PM Thread Starter
So I checked the fuse 22 and it’s good, and there is power through it. I disconnected the fuel bowl heater just to make sure but all that is good, it still won’t start. My AE scanner won’t connect, I’m not sure how to switch it to OBD1 if that’s even possible. Tried a known good PCM and still no start.
Cinahcem is offline
post #6 of 8 (permalink) Old 09-14-2019, 02:10 PM
Cinahcem,
As you can't talk to the PCM I'm betting that the PCM is not getting power. Looking at the diagrams for my 97 7.3, which should be pretty much the same as your 95.... Fuse 22 is the protection for the fuel bowl heater, glow plug relay and IDM. Fuse 22 also supplies power to the coil of the relay that controls the PCM. Check fuse 9 - this is the fuse the protects the PCM. If fuse 9 is good then check the relay that controls the PCM.
Cj
1997 F350 CCLB 7.3, Eaton Fuller RTO-6610, 4x4, 3.54, otherwise stock
cjfisher is offline
post #7 of 8 (permalink) Old 09-14-2019, 09:07 PM
I wonder if your truck is still set up as obd 1, has your obd 2 scanner ever worked with it? Or is this a recent development?
post #8 of 8 (permalink) Old 09-16-2019, 05:41 PM
Patrick Feeley's Avatar
As far as I know, the 95's did not have the OBDI port under the hood and if it did, any reflash of the PCM would have rendered it inoperable. With no WTS light, you could have a problem with a possible short on the 5V reference signal circuit. Many times a shorted sensor can cause this. For a quick check (but not definitive) for a short, unplug one of the following sensors that use the 5V reference (EBP, CPS, ICP, BARO, TPS, MAP) and turn key to WTS (you don't have to turn it over). Does WTS illuminate? Yes, that sensor is shorted. No, move to the next one. The 5V reference circuit is the white/brown stripe wire on all those sensors. EBP and ICP would be a couple of the more common culprits. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
