Road Walking / Loose Steering - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-26-2010, 01:11 PM Thread Starter
Needing Carbon Credits
I just replaced all the front end bushings and ball joints, had the truck alligned, new tires installed and checked the tie rods for play. Now it feels like the steering has alot of play and the truck wants to wander. What gives?
2wd.
05 F350 FX4 - Deleted and Exhausted
jmontes is offline
post #2 of 9 (permalink) Old 03-26-2010, 01:24 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
Re: Road Walking / Loose Steering
I am about to replace my intermediate steering shaft on mine. I found it has play in it. I thought it was in the column but wasn't.
Check that. I was told the bearings in the column tend to fail a lot too.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #3 of 9 (permalink) Old 03-26-2010, 02:12 PM
woodduck97's Avatar
The gear can have allot of play in it. Mine does and I got a tight front end.
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
post #4 of 9 (permalink) Old 03-26-2010, 07:12 PM
Have someone wiggle the steering wheel while you are underneath and you will see what is moving pretty easy.
The shop that aligned it should have noticed and fixed that. I would have. If it is just a steering box adjustment I would have just done it and not charged any more. Back in the days when garages took pride in their work that was an automatic thing. Like making sure the wheel was perfectly centered.
It's all about speed now.
I hope you didn't let them adjust caster and camber. In all my years doing alignments I've only had to adjust it once or twice and that was on wrecks where the frame was still a little bent after the frame shop finished. In all other cases something needed to be replaced that brought caster and camber right back where it belonged.
rrranch is offline
post #5 of 9 (permalink) Old 03-27-2010, 12:53 AM Thread Starter
Double R - thanks for the insight. I agree with what you say, but there is no such thing as a good shop anymore. That is why so many of us are members of these forums. They did put a 2* caster/camber sleve on the passenger side and retained the FACTORY -1/2* on the driver side. I did not quite understand why since the front end is new. The truck does track straight and the wheel is centered, but it seems the steering is much looser that before.
jmontes is offline
post #6 of 9 (permalink) Old 03-27-2010, 02:01 PM
Well, then go have your wife wiggle the steering wheel for you. It is easy to see what is wrong like that. It's probably the steering box since it was just aligned. They were supposed to do a good checkup of the steering components when it was aligned.
You can also jack up the wheels one at a time and put a big prybar under them to try to jack the tire up and down. Watch the ball joints when you do that. There is a spec for movement ad I think it's 1/8 of an inch but I don't like ANY movement.
rrranch is offline
post #7 of 9 (permalink) Old 03-29-2010, 01:47 AM
Metallitera's Avatar
prolly just need to tighten the meshload up on the gear box.
-ReD
Firefighter/Paramedic, Tinkerer
2000 Toyota 4Runner Limited 4x4
Metallitera is offline
post #8 of 9 (permalink) Old 03-29-2010, 12:22 PM Thread Starter
How is this done?
jmontes is offline
post #9 of 9 (permalink) Old 03-29-2010, 03:34 PM
top of the gear box is a stud sticking out with a nut lockin its position.
set front end on jack stands so front wheels turn freely with steering wheel.
loosen lock nut and screw stud in a cpl turns with wheels headed straight. slowly turn steering wheel from stop to stop and see how she feels. careful not to get too tight.
hold stud and tighten down lock nut
-ReD
