96 powerstroke 4r100 swap problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Mark Kovalsky
post #1 of 5 (permalink) Old 09-02-2019, 11:13 PM Thread Starter
My last e4od burned up the torque converter and overheated badly. My cousin gave me a running 4r100 and after searching the forums it seemed to be an easy swap with the help of the tci valve body performance kit. Installed the kit but had to use the 4r100 converter. Installed in the truck and ran it. The transmission at idle in gear surges between being in gear and out of gear. Both in drive and reverse. Doesn’t make a difference whether in d or 1 or 2. Is it from the 4r100 converter or something else? The kit said to use an e4od converter otherwise it could have slipping feel between shifts. But once moving down the road it shifts fine. Only have problem at idle stopped. Seems like maybe a pressure issue?
Maddogg01 is offline
post #2 of 5 (permalink) Old 09-03-2019, 02:57 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 96 powerstroke 4r100 swap problems
It does seem like a pressure issue. Low trans fluid can do this. So could a loose internal filter.
The 4R100 and E4OD converters are almost identical. They will interchange with no problem.
Mark
The good thing about science is that it's true whether or not you believe in it. ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 5 (permalink) Old 09-05-2019, 02:40 PM Thread Starter
Ok, what about a leaking cooling line fitting? I’ve slowed it to a dribble but the threads are stripped out and I need to helicoil it. It is the forward fitting into the trans. I’m not certain of the flow of oil of autos but does it go to the cooler then pan? Or does it go to the system?
post #4 of 5 (permalink) Old 09-05-2019, 06:36 PM
PSN intsigator
heavydoc's Avatar
IIRC the forward line is from trans to cooler, rear is from cooler back to trans
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is online now
post #5 of 5 (permalink) Old 09-11-2019, 12:39 AM
The front fitting goes to the cooler. The return from the cooler goes to the rear fitting, where it is used to lube the rear half of the trans. From there it is dumped to the pan.
heavydoc likes this.
Mark
