Flywheel coming apart again??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 03-26-2010, 06:11 AM Thread Starter
Why can't I get more than 60,000 miles out of a flywheel?
jacmurr is offline
post #2 of 19 (permalink) Old 03-26-2010, 11:17 AM
Old guy from the old days
Believer45's Avatar
Re: Flywheel coming apart again???
Because it is a bad design. I went with a single mass fllywheel conversion on mine the second time I replaced the clutch and am pleased with the results.
1995 F250 'Stroke 4x2 5 spd long bed, Edge Evolution CTR, homebuilt
, switched 10k, Putco Master Boss running boards, one off heavy duty
, 36" tall contractor cap, 287,000 miles.
for glow plug system help.
Believer45 is offline
post #3 of 19 (permalink) Old 03-26-2010, 05:42 PM Thread Starter
what's cost difference between another pos dual mass flywheel and a single mass conversion?
jacmurr is offline
post #4 of 19 (permalink) Old 03-26-2010, 07:07 PM
The whole kit for a smf conversion is cheaper than the DMF flywheel alone. Mine was 600 or so from valair for everything and I really like it. I already had an almost new dmf in it but a fuel leak smoked the clutch disc pretty bad.
I still have that dmf and my wife was telling me I need to sell it if your interested.
rrranch is offline
post #5 of 19 (permalink) Old 03-26-2010, 07:14 PM Thread Starter
Where can I find flywheel removal and replacement instructions for dummies? I'm not a mechanic, but I'm broke and need the truck. I'm pretty mechanically inclined, I believe I can do it, it would just be extremly helpful if I had some instruction to follow so I could proceed with confidence and hopefully only have to drop tranny one time. Any help would greatly appreciated. Thanks
jacmurr is offline
post #6 of 19 (permalink) Old 03-26-2010, 07:23 PM Thread Starter
Yeah, how much are you asking for it? Do you think I could get away with not replacing the clutch.
jacmurr is offline
post #7 of 19 (permalink) Old 03-26-2010, 07:31 PM Thread Starter
Well dammit, I guess while I'm at it, the best thing to do would be a single mass conversion, new clutch, and a whole rebuilt transmission. I just don't have the money for all that right now.
jacmurr is offline
post #8 of 19 (permalink) Old 03-28-2010, 01:27 AM
Believer45's Avatar
Flywheel from Ford is somewhere north of $1100 and does not include the clutch kit, it is just the flywheel. It will fail again in 100K or so - the complete kit from TYMAR PERFORMANCE cost me $570 three years ago delivered to my door - flywheel, clutch disc, pressure plate, throwout bearing, alignment tool. The only thing you have to re-use is the metal ring that goes on the outside (toward the back of the truck) of the flywheel under the bolts.
I replaced my clutch in October of 2000 with factory at 138K, did it again summer of '06 at 240K and the clutch disc still had 75% of the friction surface, the &@&^# flywheel failed AGAIN, taking out my transmission with it. I used the base LUK as my truck is pretty much stock and likely to stay that way. I did catch a used tranny for $600 so the total bill, tranny and all, was less than the cost at the time for the replacement in 2000.
Dave / Believer45
post #9 of 19 (permalink) Old 03-29-2010, 01:57 AM
Metallitera's Avatar
i did solid flywheel conversion from oreillys and its got a lifetime warranty on everything. been real pleased.
-ReD
Firefighter/Paramedic, Tinkerer
2000 Toyota 4Runner Limited 4x4
Metallitera is offline
post #10 of 19 (permalink) Old 03-29-2010, 10:54 PM
Learning from PSN
Diesel X's Avatar
I better plan on a clutch soon! Mine has almost 166 thousand on it. Should be back on the road this weekend. Been down for a while for electrical issue's. BTW it's a 94.5 with the original clutch.
Diesel X is offline
