1997 F350 Turbo diesel\ wont start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 08-06-2019, 01:01 AM Thread Starter
1997 F350 Turbo diesel 237K miles. Died in parking lot going 15 miles an hr...would spin over but did not start. Had it towed home... Battery is fully charged....replaced Cam Sensor —Tach is moving ( bouncing ) when trying to start—, replaced ICP, IPR,
IEOP,HEOP and the Injector drive module (no injector response / Fuel bowl is full).
Any suggestions or assistance greatly appreciated.
Vernon Hord is offline
post #2 of 20 (permalink) Old 08-06-2019, 01:16 AM
longjonsilver's Avatar
Re: 1997 F350 Turbo diesel\ wont start
Any codes ? Does the wait to start light illuminate after the key is turned on ?
longjonsilver is offline
post #3 of 20 (permalink) Old 08-06-2019, 01:47 AM
Project Shamu
Lt.Dan's Avatar
The 7.3 computer looks for 3 things when cranking.
1) 10.5v or more
2) 100rpms or more
3) 450-500psi of ICP or more
Once these 3 parameters are met, it lets the injectors fire.
Are you getting white smoke out the exhaust while cranking? If not, 1 or more of these parameters are not being met.
If you are getting white smoke, I would look at glow plugs.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #4 of 20 (permalink) Old 08-06-2019, 01:54 AM Thread Starter
Wait to start illuminates and there are no codes
post #5 of 20 (permalink) Old 08-06-2019, 01:57 AM Thread Starter
No white smoke.... replaced glow plugs ,harnesses winter of 2018
post #6 of 20 (permalink) Old 08-06-2019, 02:06 AM
Do you smell any fuel when cranking ?
What kind of live data are you able to see ?
Where there any indicators that the truck was going to stall or did it turn off like it would when you switch the engine off ?
post #7 of 20 (permalink) Old 08-06-2019, 02:20 AM
Patrick Feeley's Avatar
Any chip or other mods? What's fuel pressure when cranking? Minimum is 25 psi at 100 minimum crank speed. What are the fuel levels in the tanks and have you tried switching tanks? Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #8 of 20 (permalink) Old 08-06-2019, 02:34 AM Thread Starter
No fuel smell
No live data
Truck stopped dead no sputtering or stalling
post #9 of 20 (permalink) Old 08-06-2019, 02:36 AM Thread Starter
No mods
Do I check pressure at valve on fuel bowl
Tanks have fuel and switching tanks doesn’t help
post #10 of 20 (permalink) Old 08-06-2019, 06:04 PM
Yes, you can check fuel pressure at the valve on the Fuel Pressure Regulator (FPR) on the drivers side of the fuel bowl. You can use a cheapo stick tire pressure gauge, but wrap the joint with a rag to avoid getting sprayed with fuel. Cheers!
