Trans Overheating - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Mark Kovalsky
post #1 of 4 (permalink) Old 07-04-2019, 02:06 AM Thread Starter
Trans Overheating
Guys
Loaded up the truck and boat today to head to central Oregon for a few days of recreation. In moderate traffic trans temp was climbing higher than Iíve ever seen it. Towing the boat I typically see about 160-170. Today it climbed up to 190 then up to 210.. Once on the freeway I got it down to 185-190. Slow 3 mile descend to the campground it climbed up to 250 for a couple minutes. I have a magnefine inline filter that hasnít been change in probably 60,000 miles. Iím going to change that out before I leave hoping it is just plugged. I have an aftermarket cooler that has been on since I bought the truck with 30,000 and have 190,000 with never a tranny problem. Not sure why it is all of a sudden heating up. Tranny oil is still nice and red and not burnt. Lines in and out of the cooler were not hot. Any thought?
97 F250 California Model, down pipe, DP Tuner, ATS intercooler, 170K, Beans electronic fuel delivery, gutted EBPV
Kruegerk is offline
post #2 of 4 (permalink) Old 07-04-2019, 02:11 AM
Project Shamu
Lt.Dan's Avatar
Re: Trans Overheating
Trying blowing some low pressure air through the cooler lines and make sure they aren't plugged?
The inline filter might be plugged, I dont know much about those filters though.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #3 of 4 (permalink) Old 07-04-2019, 07:42 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
If the inline filter is even partially plugged the added restriction will open the bypass valve and the hot ATF will not get to the cooler. That filter is way overdue for replacement.
masakimm likes this.
Mark
ďThe good thing about science is that it's true whether or not you believe in it.Ē ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #4 of 4 (permalink) Old 07-06-2019, 11:19 PM Thread Starter
Wanted to post a follow up. Went to leave the campground and it hit me that anything but the stock programming on my DP Tuner raised the transmission line pressure and thought I'd go back to stock and see what happens. Well good news. Hauled the boat home 150 miles out of the canyon and through the mountains on the way back to Portland and temperature stayed right about 175 most of the way until we hit some stop an go traffic and it climbed up to 185. Came home and threw a new inline filter in and let it idle in the driveway for about 10 mins and went and ran some errands and it stayed at 150. Could finally feel some heat in the cooling lines going to the cooler. Dissected the old magenefine and there was a lot of very fine material in the pleats. That must have been enough to build pressure to operate the bypass valve and cut off flow to the coolers. Appears to be back to normal. Thanks for the help!
Kruegerk is offline
