3.55 or 4.10s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 07-02-2019, 04:12 PM Thread Starter
3.55 or 4.10s
So I recently rebuilt the motor and tranny in my truck and solid axle swapped it but the d60 I put in had 3.55 gears and I swapped my rears to match and now it's a pain to drive on the highway because it feels like it has no power in OD and is extremely smokey when trying to accelerate in OD. It's an automatic and I'm running 305 tires I was wondering opinions if I should swap back to 4.10s and deal with higher rpms at 70 or just watch the egts and deal with some sluggishness with the 3.55s. The truck has baby swamps injectors, colt cams "stage 2" cam, efuel, 3in dp and a wicked wheel 2. I just feel it should be making more power cruising in OD.
Macher7.3 is offline
post #2 of 4 (permalink) Old 07-02-2019, 07:20 PM
alleged moderator
tjctransport's Avatar
Re: 3.55 or 4.10s
with 305 tires, 4.11 gears are the way to go.
tom
tjctransport is online now
post #3 of 4 (permalink) Old 07-02-2019, 07:42 PM
danielzink's Avatar
Re: 3.55 or 4.10s
I'm running 315's (1/2" diff from 305's) on 410's....
Plenty of power in OD or otherwise.
Pulling a (loaded) 2 car all steel trailer 2 weeks ago easy 70+mph no problem.
Granted I'm running a T4 setup on Rosewood 160/80's on Tony Wildman tunes.
1997 F-250 Powerstroke, 4x4, D60, RSK, V&B's, 35" BFG ATA's on 16x10's, 6637 DIY Intake, Swamps IDM Mod, 3" DP, 4" single exhaust, Beans E-Fuel, Intercooled, Rosewood 160/80's, T4 S366SXE, Irate 3" Plenums, Terminator T500, Tony Wildman Tunes, Gauges (Pyro/Boost/Trans).
danielzink is offline
post #4 of 4 (permalink) Old 07-03-2019, 03:19 AM
Project Shamu
Lt.Dan's Avatar
Re: 3.55 or 4.10s
You have a cam in a basically stock truck???
Pull that out, I bet you make more power...
As far as Gearing, I have 35s and 4.10s with stock injs and stock turbo, and it pulls the big trailer just fine in OD.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
