Ndash to monitor gauges - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-22-2019, 06:43 PM Thread Starter
Estew2006's Avatar
So I got to reading the manual for the ndash I had for my 6.4 it says you can scan for signals for different vehicles so I hooked it up to my 96 F250 it found 198 signals to use so I tried a few out.
Injector control pressure, oil temp, coolant temp, and manifold gauge pressure as well as a few others a couple signals seemed close but others such as engine coolant was reading -40 never moved others would have no reading at all. Any thoughts on what would cause the odd reading on some of the gauges?
Estew2006 is offline
post #2 of 6 (permalink) Old 06-22-2019, 06:44 PM Thread Starter
Estew2006's Avatar
The icp reading at idle was around 500 psi and I opened it up a little on the road and when accelerating it hit about 1300 would these be anywhere accurate?
post #3 of 6 (permalink) Old 06-22-2019, 06:57 PM Thread Starter
Estew2006's Avatar
I think what I may need to do is somehow get the custom pids they are using on the forscan app and get them plugged into my ndash. If anyone has any ideas on what I may need to do to utilize my ndash to monitor gauges that would be awesome thank you
post #4 of 6 (permalink) Old 06-22-2019, 11:12 PM
Patrick Feeley's Avatar
Re: Ndash to monitor gauges
The OBS does not have a coolant temperature input to the PCM. There is only the gauge signal and the overtemp switch output to the light. Cheers!
Patrick Feeley is offline
post #5 of 6 (permalink) Old 06-23-2019, 04:02 PM Thread Starter
Estew2006's Avatar
Right on do you happen to know what sensors are useable for the obs
post #6 of 6 (permalink) Old 06-24-2019, 12:54 AM
From the Powertrain Control and Emissions Diagnosis Manual:
Inputs to the PCM:
A/C Pressure Switch
Brake Lamp Switch
CPS
Clutch Pedal Position Switch
IAT
Transmission Control Switch
Vehicle Speed Sensor
4x4 Low Switch
TPS
IVS
EBP Sensor
ICP
EOT
MAP
BARO
Parking Brake Switch
Brake Pressure Applied
Cruise Control Switches
IDM Feedback
PCM Outputs:
IDM Control
EBPV Control
IPR Control
Tachometer Output
GPR Control
WTS Signal
Cheers!
