Whats this plug? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-20-2019, 10:47 PM Thread Starter
Whats this plug?
Hi all. I am new to the forum.
I have a burning question. I was cleaning out the valley of my 7.3 1994 f350 and came across a plug similar to a freeze or expansion plug sitting under the fuel pump. It is about 1 3/16 in diameter and 3/16 inch deep. It has score marks like it had been driven into a hole somewhere but I cannot determine where. The are no leaks, the valley is mostly dry and no coolant leaks either. I am assuming it must have popped off from something but its been a while since I worked on the truck. I did all the orings on the pump, filter, and turbo and changed IPR but don't recall ever seeing the likes of this plug. Maybe behind the turbo???
ANy guess will be much appreciated.
Kim
KF350C is offline
post #2 of 7 (permalink) Old 06-21-2019, 06:14 PM Thread Starter
Re: Whats this plug?
its not the ebpv, thats smaller
KF350C is offline
post #3 of 7 (permalink) Old 06-24-2019, 01:18 AM
nothing above the engine valley will have that... anything on the turbo is half that size, looks like a typical steel freeze plug probably from previous owner dropping it in there while working on something
narmalee is offline
post #4 of 7 (permalink) Old 06-24-2019, 05:16 AM Thread Starter
Thanks. Unfortunately I am the last guy to pull everything out of the valley and put it back. For the life of me I do not know how this could have gotten there since I never messed with anything else.
KF350C is offline
post #5 of 7 (permalink) Old 06-26-2019, 09:14 AM
Blue-Truck-Nut97's Avatar
Did it fall out of the back of the alternator?
Blue-Truck-Nut97 is offline
post #6 of 7 (permalink) Old 06-26-2019, 02:36 PM
I was going to suggest the intake cover off of the vacuum pump but this suggestion seems more likely!
1996 F250 CCSB, 4x4, auto PSD, stainless window vents.
Signature file limitations keep me from sharing more information. Follow this link to find my threads: D60 RSK install, Air vent cleaning, etc.
leojr is offline
post #7 of 7 (permalink) Old 06-27-2019, 03:48 AM
You know, that same thought crossed my mind as well, then I noticed the gold plug in a rebuilt alternator in the shelf and thought hmmmm, I wonder.....
Measured the hole in mine and it was roughly 1-3/16",
Good noggin scratcher going here.
