97 severe valve recession - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 06-16-2019, 04:50 AM Thread Starter
has anyone else run into this issue?
these intakes are so bad they have knife edges on them and nearly .140 recessed PAST where they are supposed to be
when we pulled the valves the bevel of the valves is gone and turned into a bowl with a VERY sharp edge on them.... every intake valve is like this, exhaust seem perfectly fine and even within spec
Truck has 74k miles on it, yes 74k NOT 474k as you might think with this kind of wear. Cylinders and pistons look perfectly fine.
WTF over.
narmalee is offline
post #2 of 15 (permalink) Old 06-16-2019, 04:51 AM Thread Starter
Re: 97 severe valve recession
idk why the pictures didn't attach on the previous post
narmalee is offline
post #3 of 15 (permalink) Old 06-16-2019, 04:53 AM Thread Starter
apparently I cant edit my posts to put the pictures and posts together? idk... maybe cuz im new
narmalee is offline
post #4 of 15 (permalink) Old 06-16-2019, 06:27 PM
Blue-Truck-Nut97's Avatar
That is odd.......
Are you sure it's never been apart before? As in maybe someone put the wrong intake valves in? Or ground the valves wrong?
Blue-Truck-Nut97 is online now
post #5 of 15 (permalink) Old 06-16-2019, 09:14 PM Thread Starter
Originally Posted by Blue-Truck-Nut97 View Post
That is odd.......
no im not sure, there is grey Permatex silicon on the intakes and oil pan, but no gaskets or sealant on the exhaust manifolds, and the head gasket numbers are OEM gaskets, not Mahle, VR or felpro… that's what rather confusing about all of this...
valve guides are badly worn out as well, but that's to be expected with seat pressures only being about 45lbs closed with this degree of wear, the valves are going to oscillate without enough pressure thus wearing the guides
the intake valves are correct numbers, the seats are still usuable which is weird... I would have expected them to be trashed, they just need to be touched up and lapped in with the new ones
btw, does anyone have pictures of cylinder walls/pistons from a sever dustdown? im somewhat suspicious maybe that's behind this, but I don't seem to show any wear on walls or piston crown
narmalee is offline
post #6 of 15 (permalink) Old 06-16-2019, 11:18 PM
Sorry no pics here, but can you see the crosshatch in the cylinder walls? The ones I've encountered that were dusted the walls had tracks up the sides as if they were polished with sand paper, and no visible crosshatch.
Is the turbo new? If not does it show signs of dirt?
post #7 of 15 (permalink) Old 06-17-2019, 08:05 AM Thread Starter
sorry, working weird hours right now
i'll have pictures of the valves later today
the turbo has been dusted for sure, not horribly, but you can see it
the cylinder walls don't show tracks or cross hatch, so take what you will from that, cant really take pictures / work in the dark lol, neighbours seem to not like hearing mechanic noise at 3 in the morning lololol
narmalee is offline
post #8 of 15 (permalink) Old 06-17-2019, 08:18 AM
Neighbors with no sense of humor eh? Lol
I'm starting to get on board with the theory that it's been sanded with that information. Any ideas about it's previous life?
And no worries, I think we all kinda keep odd hours.
post #9 of 15 (permalink) Old 06-18-2019, 12:48 AM Thread Starter
Go figure... net is down at the house... picked up the valves today and got some good pics... I'll let them speak for themselves
Uhhh auto resize on the phone apparently shrank them so bad you cant make out the details...
narmalee is offline
post #10 of 15 (permalink) Old 06-18-2019, 02:01 AM
Master BS'er
jamiesaun's Avatar
Yeah, that's pretty worn.
Time for a head shop.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
