97 f250 throttle - PowerStrokeNation : Ford Powerstroke Diesel Forum
 4Likes
post #1 of 19 (permalink) Old 06-15-2019, 02:28 AM Thread Starter
97 f250 throttle
I have a 1997 that has recently lost power.
It will barely respond to input from the pedal on the stock tune and only build about 5 psi, with the chip on setting 6 it will go faster and make around 14-16psi.(same issue with chip removed).
I’ve checked for boost leaks, and found no issues. The engine revs very slow, like only applying 1/4 throttle.
AE scanner shows throttle is always at 0, but the engine is responding to input, just not very much.
Anyone heard of a problem like this and have suggestions?
F350 F350 is offline
post #2 of 19 (permalink) Old 06-15-2019, 03:52 AM
Blue-Truck-Nut97's Avatar
Re: 97 f250 throttle
How did your problem start? We're you going down the road and randomly lost power? We're you at a stop light and it suddenly wouldn't do anything when you mashed the throttle? Or was it fine, then you started it one morning and this happened?
Blue-Truck-Nut97 is offline
post #3 of 19 (permalink) Old 06-15-2019, 04:08 AM Thread Starter
Just got in and started it the other day in the driveway, noticed when driving away it didnít feel right.
post #4 of 19 (permalink) Old 06-15-2019, 04:34 AM
Do you hear the IVS clicking when you work the throttle pedal?
post #5 of 19 (permalink) Old 06-15-2019, 04:53 AM Thread Starter
Yes, I donít think the truck would accelerate at all of that switch wasnít working.
post #6 of 19 (permalink) Old 06-15-2019, 06:38 AM
It's not supposed to anyway, but your scanner showing a goose egg when you step on the throttle makes a guy wonder. Since your OP says you have the same problem with the chip removed, it seems to me like it's next in line. It's simple and free to check, so that's where I try to start.
post #7 of 19 (permalink) Old 06-15-2019, 01:26 PM
Patrick Feeley's Avatar
Here are the Into and Pinpoint tests for the Accelerator Pedal Sensor. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #8 of 19 (permalink) Old 06-15-2019, 03:05 PM
Project Shamu
Lt.Dan's Avatar
Scanners cannot read accelerator pedal position on an OBS, itll have to be done with a multimeter. I'm willing to bet something going in with the pedal.
Does it run fine otherwise?
F350 F350 likes this.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #9 of 19 (permalink) Old 06-15-2019, 08:45 PM Thread Starter
That is good to know, Iím gonna check it when I get a chance in the next couple of days.
Yes runs and idles smooth.
post #10 of 19 (permalink) Old 06-16-2019, 10:13 PM Thread Starter
Checked voltage at the pedal. .558v idle position and 3.97 wot
I took a video
Problem:
Problem with chip on position 6:
