P1395 again - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 (permalink) Old 06-08-2019, 09:38 PM Thread Starter
P1395 again
I've had this code more than anything else over the last 20 years. Fussed with checking resistance on the glow plugs about 3-4 years ago and finally took it in and they replaced a bank of glow plugs. It's back again. Bank 1... (Passenger side right) Ohmed all 4 GP's through valve cover harness and readings are .5 to .8 ohms. Not sure what else to do. If they are all testing within range what next?
97 F250 California Model, down pipe, DP Tuner, ATS intercooler, 170K, Beans electronic fuel delivery, gutted EBPV
Kruegerk is offline
post #2 of 12 (permalink) Old 06-08-2019, 09:41 PM
PSN intsigator
heavydoc's Avatar
Re: P1395 again
IIRC the ohm spec 2.3-3.4 ohms
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #3 of 12 (permalink) Old 06-08-2019, 10:07 PM Thread Starter
Re: P1395 again
Doing some more testing the GPR is not shutting off. Engine is warm and it's about 70 degrees. Turn the key to on and I measure 12.4 volts across both GPR terminals and after 2-1/2 minutes relay is still on.
Kruegerk is offline
post #4 of 12 (permalink) Old 06-08-2019, 10:12 PM
PSN intsigator
heavydoc's Avatar
Re: P1395 again
Sounds like your controller is bad
heavydoc is offline
post #5 of 12 (permalink) Old 06-08-2019, 10:25 PM
alleged moderator
tjctransport's Avatar
Re: P1395 again
on a cold engine block, the glow plugs can stay powered for up to 3 minutes depending on temperatures.
just because the wait to start light goes out, that does not mean the glow plugs are not still working.
tom
tjctransport is offline
post #6 of 12 (permalink) Old 06-08-2019, 10:30 PM
PSN intsigator
heavydoc's Avatar
Re: P1395 again
That is true
heavydoc is offline
post #7 of 12 (permalink) Old 06-08-2019, 11:47 PM
Bugman's Avatar
Re: P1395 again
The ohm range for the ZD-11's is 0.6 and 2 ohms for good glow plugs.
How do your pass through connectors look when you pulled the connector off?
As for the relay not shutting off, have you checked it after a few minutes. As was mentioned they can stay on for up to 2 or so minutes even when the outside air temperature is 70 degrees.
I also noticed that you show that it is a Cal truck. Does it have a regular glow plug relay or does it have the shunt on top still?
Bugman is offline
post #8 of 12 (permalink) Old 06-09-2019, 04:20 AM
Bugman's Avatar
Re: P1395 again
If he doesn't chime in here send a PM to Patrick Feeley
I believe that he is one of the best on here for questions about a California truck
Bugman is offline
post #9 of 12 (permalink) Old 06-09-2019, 04:56 AM
Project Shamu
Lt.Dan's Avatar
Re: P1395 again
The glow plugs will turn on even when the engine is warm sometimes, just not for very long. I've had a GPR fail on me a long time ago, and my truck didnt start when it was 90* outside, just white smoke out the exhaust.
So like the guys above said, make sure the GPR goes through its cycle. If the GPR didn't shut off for 5-10 min after starting, I'm assuming the wires would almost melt themselves apart, as they do draw a lot of power!
EDIT: A good read for some info on your Cali truck that I've saved; https://www.powerstrokenation.com/fo...ml#post6162251
heavydoc likes this.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #10 of 12 (permalink) Old 06-09-2019, 03:48 PM
Patrick Feeley's Avatar
Re: P1395 again
My truck would occasionally have the code too. I never knew what caused it, but I switched to a Wester Plow relay and have not had any issues in the years since. Make sure all connections at the shunt are clean and tight. I've attached a TSB regarding an issue with certain trucks as well as the Glow Plug System pinpoint tests. Cheers!
Patrick Feeley is offline
