ZF S5-47 & BW 4407 bolt up torque spec? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 06-05-2019, 03:36 AM Thread Starter
Hey Guys,
Apologies for the pester but I canít seem to find torque spec for bolting the ZF S5-47 to the BW 4407 transfer case. Did a search here and at PSA... no results and googled too, nuthin. Also need specs for ZF bell housing to block torque specs would be most helpful. Probably over thinking but they are all cast aluminum (save for the block), and not wanting them to come loose the notion is to over tighten and strip..... doh... thinking Iíll use blue locktite on the Tranny to Tcase bolts as well a size drive line bolts...
Thanks in advance.
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4Ē exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
post #2 of 3 (permalink) Old 06-05-2019, 04:56 AM
Bugman's Avatar
Re: ZF S5-47 & BW 4407 bolt up torque spec?
According to my manual the transfer to transmission bolts are 30-40 ft/lbs. Tightened in a star pattern.
The transmission to engine bolts are 39-53 ft/lbs.
It doesn't say anything about loctite or antisise on either.
Bugman is offline
post #3 of 3 (permalink) Old 06-05-2019, 05:05 AM Thread Starter
Thanks Bugman... confirms what I found. Finally remembered I have a digital shop manual in my Dropbox account, knew I had one somewhere, was just locating it... bahahahaa
Transfer Case to Transmission Extension Housing 41-54Nm 30-40 lbs ft.
The T case to extension did have loctite on the threads from factory, engine to tranny Iíd say none.
Thanks again
j
JCart is offline
