trans,clutch/master cyl problem.. help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-25-2010, 02:14 AM Thread Starter
well today my saftey switch went out and while i was replacing it i did the "permanent clutch problem fix" to replace to plastic bushing...
well it didnt fix he problem. its hard to down shift the truck and i cant get it into gear sitting at idle.
i noticed today under the dash the back of the clutch master cyl was leaking a little.
from some research ive done the clutch master cyl could be causing my problem. and i would like to fix this problem before the trans get damaged.
heres a link to a master cyl i thought of buying
Zip Code Select | O'Reilly Auto Parts
1997 f250 supercab shortbed
7.3 PSD
4X4 5 speed
stage 2 afe intake
4 inch MBRP exhaust
3 inch MBRP down pipe
full force stage 1 injectors
some gauges
intercooled
terminator modded 17* hpop
dp tuner f5
ccarrier is offline
post #2 of 5 (permalink) Old 03-25-2010, 03:06 AM
Nitro41's Avatar
Re: trans,clutch/master cyl problem.. help!
i got the napa master cylinder. its pretty nice and was priced well.
it definetly sounds like the clutch isnt disengaging all the way. i would advise you dont drive the truck if its that bad. youll tear up your synchros QUICK!
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
T500 HPOP
OFE clutch
Linex rockers
35" Toyo M/Ts
and a bunch more...
Nitro41 is offline
post #3 of 5 (permalink) Old 03-25-2010, 03:09 AM Thread Starter
so you think i should i get clutch master cyl?
7.3 PSD
4X4 5 speed
stage 2 afe intake
4 inch MBRP exhaust
some gauges
intercooled
dp tuner f5
ccarrier is offline
post #4 of 5 (permalink) Old 03-25-2010, 04:58 AM
Strokin'
With it leaking i would change it.
as for not getting it into gear.. do you have a full pedal or is it low/closer to the floor? Has the clutch, pressure plate, throw out bearing etc been change?
I myself wouldnt reccomend driving the truck if it grinds when trying to put it in gear at and idle.
94' F-250 PSD, Reg. cab, 4x4, ZF-5, K&N, 3" DP, 5" Exhaust.
93' F-250 SCLB, 4x4, Gas.
88' F-350 460 Wrecker. Lots of LED's.
The Bank doesn't own my trucks.
jakeloney is offline
post #5 of 5 (permalink) Old 03-25-2010, 05:11 AM
your mom
RMPowerstroke's Avatar
change it if its leaking.
f350 king ranch dubed. ol ranchero thanks to wayne
04 cc/lb 9inch lift C-6 built converter custom revs manual valve body r servo. powered by 12v cummins p-pump 4k gvs custom lasered dlv pump work, 5x16 sticks, singler charger for now, airdog150, its on meth lots of custom junk. hids road armor bumper and im truck broke
06 f-150
RMPowerstroke is offline
