97 F350 Frame Repair - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-29-2019, 12:21 AM Thread Starter
Hey guys new to the forum and was looking for some help on frame rust. I live up in the rust belt and its starting to go through/crack near the rear spring shackle on the driver side. Passenger side is good and the rest of the driver side looks good too. Ive heard of some guys cutting and patching sections and others cutting the entire back half of a donor frame and welding it in. Guess i wouldn't know exactly what's going on until i strip everything down and see what's left. I thought about just biting the bullet and sending it out to a body shop/ fabrication shop if i could even find someone to take it on. I'll attach a couple of pictures id really rather fix it then get rid of it. Let me know what you guys think any help would be appreciated.
kbevs123 is offline
post #2 of 2 (permalink) Old 05-30-2019, 01:38 PM
CAT lover
Robertl211's Avatar
Re: 97 F350 Frame Repair
Just did this exact same thing on my 96. I removed the bed. junked it. Removed fuel tanks, lines, and harnesses. Had a dustless blaster guy come and blast the entire frame from the cab back. Had horrible holes, the spring hangers were less than paper thin, and the cross members were gone. I cut out the rust holes, the metal around it was still surprisingly good, and welded in new patches. replaced the cross members with 2" channel and 3" square on the rear. New spring hangers the chassis savered the entire frame. New rear tank and then a flatbed. It came out AWESOME! I couldn't believe how bad it was once it was blasted.... SCARY bad. I couldn't believe it didn't break in half towing a utility trailer, let alone my 11k boat/trailer that i tow EVERYWHERE. Glad that is over. I made a thread about it.
My endeavor starts on page 5 basically. I ended up doing it myself after a long and expensive ripoff from a dick that took my money and ran.
https://www.powerstrokenation.com/fo...-debate-5.html
96 F250 RCFB 4x4 7.3
96 f350 CCLB Dually ZF5, custom flatbed, Gregio Medio Lamborghini paint, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
