1997 F250 Cooler confusion (pics) - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-26-2019, 06:59 AM Thread Starter
Good evening everyone,
This is my first post on this forum. I recently purchased 1997 F250 7.3 for some after work projects here and there. I am confused with the Cooler situation. It looks like previous owner added some extra coolers. Small cooler was originally bolted on the bumper. I am not going to tow with this truck, just like I said it will be a project truck :) Can I disconnect small cooler and seal off the ends? If you could give some explanation on what was done, please do :) I can take more pics if needed. Thank you for any help.
smushmaks81 is offline
post #2 of 5 (permalink) Old 05-26-2019, 11:47 AM
longjonsilver's Avatar
Re: 1997 F250 Cooler confusion (pics)
That looks like a transmission oil cooler . You’ll want to keep that on the truck for sure .
Follow the oil cooler lines back and confirm that they do indeed go into the transmission.
Post some more pictures, that intercooler and the over/under drive is really interesting.
Welcome to the forum .
longjonsilver is offline
post #3 of 5 (permalink) Old 05-26-2019, 12:42 PM
410customs's Avatar
Welcome to PSN
Your new 97 appears you have some nice upgrades!
First off your 97 is intercooled, congrats! This is a very good upgrade for the obs, especially if you do any towing
They added a larger aux transmission cooler
It also appears to have a banks exhaust brake
And a gear vendors overdrive
Those are some nice upgrades when installed properly and working! How do you like the truck? Are you in contact with the previous owner?
2001 Excursion 7.3, auto, 4x4, 3.73, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
21.9 liter family
410customs is offline
post #4 of 5 (permalink) Old 05-26-2019, 03:07 PM
Native Texan
masakimm's Avatar
Garage
Well it will depend on how it was tied in if it was added inline with the radiator cooler then u would have to hook the return line back to the radiator cooler. if it is hooked up as a stand alone then you would have to hook back to the radiator cooler. I would just leave it as heat is the number one killer of transmissions. and u don't have to be towing to build heat. aslo make sure it was not added for the gearvenders unit.
I was born into Gobernment health care. And will die in Gobernment Health care. God Bless Our Military Men And Women.
Upgrades:
masakimm is offline
post #5 of 5 (permalink) Old 05-27-2019, 03:54 PM
I’d check to see if this in bumper cooler is linked to the transmission and leave as is, the E4OD auto tranny in these trucks are prone to failure the cooler you keep tranny temps the better. Looks like you’ve some great mods already, Banks engine brake and gear venders are really nice mods. Is your truck 4x4 of 4x2?
Welcome to PSN.
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4” exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
Similar Threads
91 f250 radio install confusion diesellaxer Aftermarket Electronics and Lighting 3 09-05-2011 05:51 PM
tranny confusion blamedachevy 1994-1997 Power Stroke Technical Info 9 09-17-2010 02:21 AM
Clear up some shock confusion.... 96'BigBlue 1994-1997 General Aftermarket 12 07-12-2010 01:08 AM
Wheel and tire confusion 1tontoy 1994-1997 General Aftermarket 13 05-05-2010 03:07 PM
Forged Rod info confusion strokin_early_99 7.3L Power Stroke - Aftermarket & Performance 62 12-11-2007 04:45 AM
