HPOP install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-23-2019, 07:45 PM Thread Starter
SAR Member
amccloud's Avatar
HPOP install
What would stop you from installing a 99 HPOP in a 96?
amccloud is offline
post #2 of 2 (permalink) Old 05-23-2019, 10:58 PM
Re: HPOP install
Nothing.... I’d recommend the kit from Riffraff Diesel to install, it establishes stout steel threaded bushings (like a helicoil only better), in the aluminum front cover as the bolts that hold the HPOP are prone to stripping. Also get new gasket. The newer pump is a higher capacity and not a bad option if it’s free/very low cost. Aftermarket options for higher capacity are even better, especially if you’re running larger injectors.
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4 exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
Similar Threads
Inj. sleeve install - install inj immediately?? ofarrellfitz 7.3L Power Stroke Technical Info 6 08-31-2017 05:23 AM
Prosport EVO 60mm EGT gauge install Ford F250 powerstoke 6.0 install fintech 6.0L Power Stroke - Aftermarket & Performance 0 10-19-2015 02:19 AM
4739 install using dieselsite install kit nation1979 Transmission Related 3 09-20-2010 10:41 PM
hpop install uninstall time mustang_gt_350 7.3L Power Stroke Technical Info 9 04-04-2008 05:24 PM
17* hpop install 96strokerwg 1994-1997 OBS Power Stroke - Aftermarket & Performance 6 02-25-2008 05:32 AM
