Simple fix for fuel tank filler vent problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
  • 3 Post By LOD
post #1 of 2 (permalink) Old 05-14-2019, 03:33 AM Thread Starter
LOD
Hi All,
I've come across so many great suggestions here, and now I might have one to return.
The fuel tanks on my 1997 F250 had a severe venting problem, where I could only fill them at a very slow rate. Too fast, and the fuel would foam up and overflow at the filler port. Looks like a lot of other folks have had this problem too.
Here's an easy fix that worked great for me. It doesn't require adding any parts, or removing the fuel tanks. Since I can't post photos yet I threw together a webpage with photos showing the modifications: The page is at lod.org/misc/DieselFillerFix.html
Sorry if this mod has already been posted, but I didn't see anything similar. Let me know if it works for you!
LOD is offline
post #2 of 2 (permalink) Old 05-16-2019, 05:17 PM
Re: Simple fix for fuel tank filler vent problem
That’s a great option too.
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4” exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
Similar Threads
Fuel tank strap broke, Fuel filler neck kinked techguy7.3 7.3L Power Stroke Technical Info 0 11-12-2018 10:04 PM
Marine Fuel Tank Vent Shovel 1994-1997 Power Stroke Technical Info 5 06-18-2015 11:56 PM
How to fix this dryer vent problem? clydesdale General Questions & Discussion 19 02-17-2012 01:39 PM
Cheap fuel tank vent fix.... K5383 1994-1997 Power Stroke Technical Info 9 07-06-2011 01:17 PM
fuel tank filler neck....I think I messed up! TNScrambler 1994-1997 Power Stroke Technical Info 5 10-18-2010 04:28 PM
