Bad fuel sensor in tank - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 11 (permalink) Old 05-13-2019, 10:34 PM Thread Starter
Got a 1996 Ford F-450 Powerstroke and the front fuel tank is full but the gauge reads empty. We have current going to the tank and when I pulled out the assembly from the tank today heard fuel sloshing around in the float, that was one problem but when I took it to the mechanic to test the electric slide switch (rheostat??) We found that it worked when the float was down and continued showing an increase in electrical data as the float was lifted but when we got to about 2/3 up, it puked out on us dead. It is a bad switch.
I took it into the local Ford dealer and they wanted about $20 for the little metal float barrel but they did not sell the little electrical switch and said I HAD TO BUY THE ENTIRE UNIT.!! WHAT A RIP OFF!!!.. And the price?? WAY north of $200
I refuse to be ripped off by Ford here, You can find all kinds of fuel sending units, complete for all kinds of cars for around $30.
So, any MacGyvers out there to tell me where I could buy just the switch and mount it to where the old switch snaps in?
I realize there will need to be a match up for the current coming from the switch in the cab to the sending unit to get a accurate reading, but if i can just get something close would make me happy. I can drain the diesel out of the float and JB weld the little crack I see where the leak is.
Thanks
cantankerous is offline
post #2 of 11 (permalink) Old 05-14-2019, 12:44 AM
Bugman's Avatar
Re: Bad fuel sensor in tank
You can have the sender rebuilt.
Somewhere in the forum here in the last 6 months I believe a member posted a link to a shop that rebuilds them.
cantankerous likes this.
Bugman is offline
post #3 of 11 (permalink) Old 05-14-2019, 03:47 AM Thread Starter
Thanks Bugman I will see what is out there in computerland in the morning..
post #4 of 11 (permalink) Old 05-14-2019, 04:34 AM
Bugman's Avatar
It wasn't too far away in a search.
Rebuilt Fuel Sending Unit Specialist
Bugman is offline
post #5 of 11 (permalink) Old 05-14-2019, 05:30 AM
the wholeing sending unit with float is cheap on ebay.
78-79fordman is offline
post #6 of 11 (permalink) Old 05-14-2019, 05:33 AM Thread Starter
Thanks again Bugman, I'll give them a call tomorrow. Now I need to find an operating manual for the John Deere 830 tractor I just bought tonight.
post #7 of 11 (permalink) Old 05-14-2019, 05:36 AM Thread Starter
I checked out E-Bay a while back when I knew this was going to be a problem and a lot of sending units but not the one for this truck. i will check them again tomorrow, thanks
post #8 of 11 (permalink) Old 05-14-2019, 12:20 PM
HilhavenFarm's Avatar
The above company was my post. I have used them before and was satisfied.
I have also bought the float on Summit Racing.
https://www.summitracing.com/parts/sdk-c8zz-9275-c
https://www.summitracing.com/parts/sdk-c0az-9202-b
1996 F350 XL Crew Cab LB 4x4 3:55
Former Ft. Bragg/Pope AFB Truck
DieselSite Coolant Filter
Riff Raff Diesel Turbo & Y Boot Kit
Riff Raff Diesel HPX
Mile Marker 449SS Manual Hubs
1987 F250 XLT Lariat LB 2WD 4:10
6.9/7.3 IDI Swap-SOLD
2010 John Deere 5055D
1974 Deutz 5506
2950 hours-"The Tank"
HilhavenFarm is offline
post #9 of 11 (permalink) Old 05-15-2019, 04:36 AM
didn't notice the f450 part . I wonder if it's the same front tank as a f350 .
post #10 of 11 (permalink) Old 05-15-2019, 01:15 PM
I am unsure, but was told it was same when I was inquiring on parts and working thru my issues.
1974 Deutz 5506
Similar Threads
Buying a used Fuel tank sensor cantankerous 1994-1997 Power Stroke Technical Info 4 11-05-2018 09:44 AM
1996 in-bed transfer tank/fuel tank conversion JoeVet 1994-1997 OBS Power Stroke - Aftermarket & Performance 7 11-07-2016 10:46 AM
bad icp sensor = bad fuel milage? bigblocktisdale 7.3L Power Stroke Technical Info 16 12-30-2015 05:50 AM
"offroad Trucks" DEF tank as extra fuel tank? hood72 11-16 6.7L Power Stroke Technical Info 2 11-02-2013 12:46 PM
00 SB fuel tank bad venting farmboy930 7.3L Power Stroke Technical Info 5 01-10-2013 08:39 PM
