HPOP question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-07-2019, 02:37 AM Thread Starter
joserollin's Avatar
HPOP question
Hello everyone
I got a 97 f250 356k on the clock my issue is from a light wot my truck Boggs down my torque app reads 1,300 instantly on my HPOP gauge and through the rpms makes it all the way to 2,450 but if I’m cruising and I go wot my HPOP spikes 2,550 instantly and holds 2,490 or so and my truck responds with no issues I have installed
new IPR new ford ICP and CPS I don’t have issues starting it fires right up No miss fires idles smooth has anyone had issues like this before what else could I look at or is my HPOP done for?
joserollin is offline
post #2 of 5 (permalink) Old 05-08-2019, 12:31 PM
Never Stop Building
neverstopbuilding's Avatar
Garage
Re: HPOP question
I'm curious about this as well, my truck has some similar issues. It may very well be a fuel restriction? Do you have a way to measure the fuel pressure?
Perhaps off the line you don't build enough fuel pressure quickly, however while cruising, you have sufficient pressure?
- Jason
2000 F-250 Super Duty 4x4 "The Dream Machine"
Carpenter and Japanese Woodworker
Never Stop Building
http://www.neverstopbuilding.com
neverstopbuilding is offline
post #3 of 5 (permalink) Old 05-08-2019, 06:05 PM Thread Starter
joserollin's Avatar
When I bought the truck the fuel pump was bad so I replaced it about 9 months ago I was hoping that was gonna fix the issue but it didn’t past weekend I took the whole fuel bowl out cleaned it up and also took apart the fpr and removed the metal filter that is on top of the return line to the tank just to see if that was the issue and nothing I also have it shimmed I don’t have a gauge to measure the fuel pressure down the road but I did check it at idle and revving it up at the house and I’m having 60-80 psi at idle so I’m honestly at a lost. have you done anything to figure out your issue ?
post #4 of 5 (permalink) Old 05-08-2019, 06:28 PM
Native Texan
masakimm's Avatar
Garage
Re: HPOP question
What is ur Ipr percentage running that will tell alot about how hard the pump is working to build enough pressure. if the ipr reading is always high then the pump is weak.
Explosive Diarrhea not ur friend but a great weight loss tool.
Upgrades:
masakimm is offline
post #5 of 5 (permalink) Old 05-08-2019, 06:48 PM Thread Starter
joserollin's Avatar
At idle im at 12-12.4 under wot it maxes out at 34-35
Similar Threads
HPOP check springs at HPOP lines NorCalDiesel 7.3L Power Stroke Technical Info 2 03-25-2019 12:24 AM
hpop question on a 97 7.3 also a d66 question truckerchuck76 1994-1997 OBS Power Stroke - Aftermarket & Performance 33 11-06-2014 09:56 PM
15* hpop to 17* hpop Powerstoke_Fan 7.3L Power Stroke - Aftermarket & Performance 16 02-20-2010 12:49 AM
obs hpop vs. sd hpop powerstroke742008 1994-1997 OBS Power Stroke - Aftermarket & Performance 8 01-03-2009 02:14 PM
Checked my hpop with AE....lotsa hpop data inside SmokeWagon 7.3L Power Stroke - Aftermarket & Performance 11 10-29-2007 03:57 AM
