7.3 needs pump from gas pedal to start.. why? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-30-2019, 08:42 PM Thread Starter
Ford E350 1997 7.3 diesel 260k
The engine will just crank and not start...... UNTIL I tap the gas pedal then the engine starts. The 7.3 will also start right back up after it runs, but after a few minutes of the 7.3 not running, I need to tap the gas pedal to get it started again any thoughts?
Air temp 60 degrees
Thanks in advance!
Jeff
greenglowdiesel_nat is offline
post #2 of 2 (permalink) Old 05-01-2019, 02:14 AM
Patrick Feeley's Avatar
Re: 7.3 needs pump from gas pedal to start.. why?
All I can think of is possibly a stuck Idle Validation Switch (IVS). Maybe try some spray electrical contact cleaner on it. Cheers!
Patrick Feeley is offline
Similar Threads
Locking Gas Door or Locking Gas Cap SlappinGills 1994-1997 General Aftermarket 11 09-25-2015 11:07 AM
gas pedal not working papapatsy 7.3L Power Stroke Technical Info 11 09-20-2011 06:43 PM
99-04 gas pedal assembly bankspowerstroke Engine & Transmission Conversion 4 03-11-2011 06:58 PM
check engine light comes on when hit gas pedal 96strokersmokin 1994-1997 Power Stroke Technical Info 1 03-06-2009 04:28 AM
