post #2 1995 powerstroke will turn over, won,t start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-26-2019, 08:54 AM Thread Starter
l started a post on here but wanted to start from beginning, truck was running like a champ, parked it at work and when l got ready to leave it would,nt start. ran battery down trying to start it. got looking and found on driver side front the pig tail and injector connector was burnt and madded together. replaced gasket and pigtail still won,t start am l missing something with that. thanks
rayroof10 is offline
post #2 of 3 (permalink) Old 04-26-2019, 11:03 AM
longjonsilver's Avatar
Re: post #2 1995 powerstroke will turn over, won,t start
Check your fuses on the drivers side engine compartment . You might have blown one or two . You notice any smoke from the tail pipe while you’re cranking ?
Make sure the battery’s are fully charged as well since you said they were discharged from cranking .
longjonsilver is offline
post #3 of 3 (permalink) Old 04-30-2019, 08:00 AM Thread Starter
No smoke from tail pipe and battery"s full.
Similar Threads
95 7.3 powerstroke turn over won,t start rayroof10 1994-1997 Power Stroke Technical Info 1 04-25-2019 11:54 AM
TRUCK WON'T START OR TURN OVER. NEED ADVICE 96stroker96 1994-1997 Power Stroke Technical Info 6 02-19-2011 10:39 PM
Has power but won't turn over dan_k 6.0L Power Stroke Technical Info 12 12-15-2010 02:25 PM
Sometimes won't turn over, sometimes will ezeggs 1994-1997 Power Stroke Technical Info 11 02-20-2010 12:30 AM
Truck won't start/turn over?? jensenciv10 7.3L Power Stroke Technical Info 1 02-23-2009 04:30 AM
