1997 7.3 towing - PowerStrokeNation : Ford Powerstroke Diesel Forum
 5Likes
post #1 of 131 (permalink) Old 04-25-2019, 01:56 AM Thread Starter
1997 7.3 towing
So I got this truck thatís been sitting for 3 years and today was itís first day at work. Iím hauling a 7x16 enclosed trailer with 2 big zero turn mowers in it. I was using a 98 Chevy k1500 with the 5.7 that did fine. I donít understand all the hype about how ď7.3 will pull a house downĒ that Iíve seen in the past but from a dead stop it takes 30 seconds to get to 60mph and on the free way it wonít hold 65 going up a hill. I have 4:10s my half ton hauled the same set up and would do so much better. Is there something wrong with my truck?
eric.wasilko is offline
post #2 of 131 (permalink) Old 04-25-2019, 02:23 AM
Blue-Truck-Nut97's Avatar
Re: 1997 7.3 towing
What transmission do you have?
What RPM are you turning at 65?
Mine is an E4OD with 4.10's, and does not like 65.
Blue-Truck-Nut97 is offline
post #3 of 131 (permalink) Old 04-25-2019, 02:25 AM
somethings it wrong
78-79fordman is offline
post #4 of 131 (permalink) Old 04-25-2019, 02:33 AM Thread Starter
Re: 1997 7.3 towing
Itís automatic and at 65 itís about 2500-2700 rpm I canít remember exactly
post #5 of 131 (permalink) Old 04-25-2019, 02:44 AM
longjonsilver's Avatar
Re: 1997 7.3 towing
How many miles on the truck / engine?
longjonsilver is offline
post #6 of 131 (permalink) Old 04-25-2019, 02:46 AM Thread Starter
Re: 1997 7.3 towing
274,600
post #7 of 131 (permalink) Old 04-25-2019, 02:52 AM
1997 7.3 towing
Originally Posted by eric.wasilko View Post
274,600
Might be in need of a set of injectors .
But first , have you serviced it ? Oil and filter change . These engines use high pressure oil to fire the injectors and if the engine oil is used up then they run - not as well as then could . New fuel filter ? Checked the air filter ? If that truck set any length of time then thereís a possibility that the air filter box is full of mice nest stuff .
Have you cleaned the fuel strainer in the fuel bowl ? That strainer is bad for getting full of trash and cause a no power issue like the truck is doing you now ....
these trucks arenít rockets but they should walk all over a 5.7 , and no not because itís a Chevy .
post #8 of 131 (permalink) Old 04-25-2019, 02:54 AM Thread Starter
Re: 1997 7.3 towing
All That stuff was changed while I was working on it trying to get it to start I donít remember looking for trash in the fuel bowl I can look tomorrow tho. But as of right now the 5.7 would destroy the 7.3 but Iíd like for it to be the other way around
post #9 of 131 (permalink) Old 04-25-2019, 03:00 AM
1997 7.3 towing
The strainer in the fuel bowl is part of the fuel pressure regulator on the fuel bowl. It will require some disassembly to get to it and a few cans of brake clean and compressed air to clean it . Youíll also need some new Orings too while youíre in there .
One other thing you can check is to make sure the exhaust back pressure valve is open all the way / is functional as well . If youíre in a warm climate unplug it , itís a oil leak waiting to happen and a restriction on the exhaust .
post #10 of 131 (permalink) Old 04-25-2019, 03:03 AM Thread Starter
Re: 1997 7.3 towing
I live in middle TN our weather is whatever it chooses to be but Iíd say itís more warm than cold
Similar Threads
Pre-trip recommendations for towing with a 2000 7.3 liter used for towing 10 K equislover 7.3L Power Stroke - Aftermarket & Performance 9 03-29-2015 10:16 PM
10 mpg towing ,empty,up hill and down! 1997 f3504x4 Suck! Bobsyourman 7.3L Power Stroke Technical Info 15 02-23-2013 12:42 PM
Towing temps and issue with over 10k towing tlb017 6.4L Power Stroke - Technical Info 9 04-13-2012 04:51 AM
