1996 Axle Swap Leaf Spring brackets. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-23-2019, 02:27 PM Thread Starter
I bought this truck about 4 years ago, The leaf spring clunks when I turn, And it rides horrible. I found out it has 03' super duty's axles & the leaf spring doesn't fit correctly.
Search on google for brackets, but I have no idea what to order.
If anyone could help that would be awesome.
overclocked is offline
post #2 of 3 (permalink) Old 04-23-2019, 07:04 PM
alleged moderator
tjctransport's Avatar
Re: 1996 Axle Swap Leaf Spring brackets.
welcome to PSN.
F-250??
my bet is when the did the axle swap, they left the 250 IFS springs in it.
F-250 IFS springs are very stiff to compensate for the lateral stress put on them by the twisting of the axles. when you put a solid axle in with 250 springs, you end up with a lousy ride.
you most likely need to switch the front springs for a set of F-350 springs.
tom
tjctransport is offline
post #3 of 3 (permalink) Old 04-23-2019, 07:58 PM Thread Starter
Originally Posted by tjctransport View Post
welcome to PSN.
F-250??
Thank you for the response, My truck is an f250, the axles & and springs are out of a 03' f350 to my knowledge.
I think this is what i need to fix the issue:
1992-97 OBS RSK SD Spring Hanger Conversion Kit
Ugh won't let me post link
Similar Threads
Front 4x4 axle swap 99 leaf spring to widetrack with coil suspension simply_peter Suspension and Drivetrain 2 05-06-2014 01:33 PM
Leaf Spring swap-Now question? jeffro22 6.0L Power Stroke Technical Info 5 12-09-2013 05:35 PM
Leaf spring to coil spring conversion... (Question) lseez Suspension and Drivetrain 30 05-22-2010 06:07 AM
Leaf spring Texas guys...want to swap your stockish suspension, etc for my lift? Suns_PSD 1999-2010 Super Duty General Aftermarket 4 12-01-2007 01:12 AM
